Not SVX related but I would like to ask you anyway
My question is about the coil paks for the 2.5l Legacy outbacks. Yes I know it's in the wrong section but I figure you are a tech and you would probably be the best person to ask.
Is there a certain mileage that they should be replaced? (i.e.- sparkplugs every 30,000 miles, stuff like that) Thanks for the input.:) |
The answer will come from someone who knows about this. Chris is not here to answer the questiions, but we use it as the tech area. I will move it over to non svx, but someone may answer your queston. :)
Is he talking to me??? I'm Chris... :)
Re: Not SVX related but I would like to ask you anyway
No, there is no maintence schedule for the coil pack. |
how often do they go bad? Are the paks from the 2.2's the same?
Well, I don't have experience with Subarus in particular, but generally it depends. Sometimes a coil pack will last for the life of the car, sometimes it will fail early on. My mother's Buick Century with 166k miles hasn't thrown a pack yet. So It really isn't something you can predict.
A little OT, but I would really like to hear about your MR2 project, as I own an 85. I assume you are already a member over at www.board.mr2faq.com . |
Well, Mr 2 is sitting under a pile of snow at the moment, but, when it gets warmer(above 35 degrees) I'm gonna try to get the motor working and then install the turbo. I have 2 of them that I can pretty much interchange between the two, IHI's are cool like that. Or I can stick a Northstar V8 in it and cry about how much ECU wiring I have to do.:D :cool: ;)
(btw, that's in reference to Mr Strong's project:)but I think you know what I mean:) |
Of course, I've been following that project since Day 1. Just can't wait to see it this summer. He better have it done. :)
Why not it's in OT. Did you say Northstar in an MR2? Why? Won't it be more weight with less power potential and less room to work on? Not to mention the broken cylinder liners:rolleyes:
As long as the connector and spark plug boots are the same at the coil they will interchange. |
I wouldn't worry. This thing will fly. And you may just read about it in a magazine sometime next year. |
Wasn't he saying he was going to boost it as well?
rperry03, thanks for the info, I'll check it out tomorrow. :cool: |
PS I can't spell to save my life... :rolleyes: |
I'm not saying it won't be fast, it's just that you can make 350hp with the 4cyl thats in there. And I too will have to disagree with the weight specs, a Northstar has to weigh more than 100lbs over the Toy motor. More weight will always meen less handling, and how much hp do you need to spin the rear tires anyway?
I just cring at the idea of swapping in a POS Northstar in place of the 4cly. If you want more touqe I'd go with a supergharged Toy V6. |
See, the best part about the Northstar is that it is all Aluminum. It does not weigh all that much. It weighs less than 500 lbs, and he is stripping all the uneeded stuff, so in reality it will weigh a lot less. I did misspeak about the weight though. I was comparing it to the 4AGE, when in fact I really meant the 3SGTE (MK2 T engine), which is becoming a quite popular swap into the back of the MK1 MR2. And if you think the extra weight is a handling issue, than talk to the owner of the original MK1.5 (name for a 3sgte MK1). I'm sure he will be more than happy to show you the error of your thinking.
And while it is possible to get 350HP out of the 4AGE, you have to remember that it is only 1.6 litres. 350 is getting pretty close to pushing the envelope. Just ask Bill's friendly rival who is attempting to build a monster 4AGZE (supercharged engine) who is currently on his 3rd rebuild. And as to the why factor, I'm pretty sure its the same reason that you are building a monster wagon- you could always go get a truck, but the monster wagon is just friggin cool. |
OK
I put a coil pak on from a 2.2l legacy. So far it's working great. Nice smooth idle and responds well . I'm still getting a new one though, I 'll have that tomorrow. Now I just gotta stop using crappy gas if I can help it.:rolleyes:
Thanks very much for the input guys.:) |
