SSM fow Windows updated
Hi,
Thanks to Mr. Ishikawa's cooperation, the 4WS information reading function has been debugged. The latest version Build 240204 has been uploaded. An SSM cable is required to use this software. Additionally, the 4WS feature is only available in JDM version L. https://grove-design-service.com/ssm/ssm_svx_en.html |
Re: SSM fow Windows updated
I recently received an inquiry about a cable for my SSM software in my web site. (This software is not only for SVX). He (or she) said he couldn't make the cable himselvs so he want to know how tou buy them somewhere?
BTW, the link below seems has expired. Select Monitor (SSM1/OBD1) USB Cable https://www.subaru-svx.net/forum/showthread.php?t=55418 EvoScan cable seems still available. https://evoscan.com/product/subaru-s...baru-vehicles/ Does anyone have it and using it? I want to know EvoScan cable is valid for my SSM software or not if anyone still having it. but, I do not want to purchase it to confirm for someone.... |
Did you ever find your answer?
No new information has been received from SVX owners. However, SSM for Windows is also available for the Impreza revision, and is used by an SF5 Forester owner in Hawaii. The SF5 uses almost the same engine as the GC8 Impreza, so it is very similar.
He said that the EVO Scan cable can be used, which means that the EVO Scan cable uses the FT232R chip. I think that the EvoScan cable can be used without any problem with the later SVX from '95 onwards. There are many types of EvoScan cables, so please pay attention to the shape of the connector. The SVX has a 9-pin square connector, not an ODB connector. The '91-'92 SVX has a problem with voltage levels of communication signals in ECU which may cause the EvoScan cable to give unstable readouts and run very slowly. I have designed a circuit to offset that voltage and have published it on my website. I had a spare '91-'92 special cable that I recently sent to Mike621. I hope it helps him. So, I have some parts in stock to make a similar cable. If you or some other person needs a '91-'92 cable, I may be able to assemble it. If your SVX is a later model, the choosing the EvoScan cable is easier way. |
I've received several emails over the last few months inquiring about SSM cables.
The NL37WZ16USG device I used does not appear to be available any more. I have been shown a compatible replacement IC, but so far it does not seem to work well. So, from today, I am starting to assemble cable using stocked IC. I will be able to 20 pcs of cable for '91-'93 SVX as maximum. The IC is so small that you will need to use a magnifying glass. |
I'm continue the assembling SSM cables today.
The IC and its surroundings are finished, so tomorrow I will attach the pins to the connector. |
How are you going to sell these? I would be interested in purchasing one.
The price will be a same worldwide price of USD 90 including shipping. I previously offset the cost of the cam position sensor with Mike. The price come from that. Shipping costs vary slightly depending on the country, but I like to keep it simple. It's a bit more expensive than the EVO Scan cable, but it's up to you whether you buy a finished cable that's actually SVX tested, use the EVO Scan cable, or make ones own. You can use my PayPal account to make the payment. Selling semi-finished products can cause trouble, so I do not intend to sell just PCBs for now. I like to make it complete cable and check it with my SVX. Please don't pay before I finished to make and check cables. |
Today, I was assembled SSM connector. I have 10pcs connector for now.
Most of the donations to SSM for Windows and the sales of cables are used for the development of SSM. Currently, we are searching for parameters together with the owner of a '97 twin turbo Legacy.
I bought some SSM cassettes from eBAY. I designed hardware to read the ROM contents of the cassettes via USB, and am reading the contents. I am also creating tools to analyze the contents. Some cassettes seem to have functions for TCU, air conditioning ECU, cruise control, and immobilizer, just like the SVX. |
I made two cables tonight.
I will check it tomorrow. |
Today I checked SSM cables with my SVX.
Cables are working fine. Now I have two cables for '91- and one cable for '95(no voltage offset). Send me PM with shipment address if you want to purchase. I will assemble few more, but I will be shipped on a first-come, first-served basis. As quantities are limited, please do not pay before confirming your order. You can pay with PayPal. |
Today I got an offer from someone in West Virginia, USA, to buy. This Thread will be moved to the ForSale thread. I will assemble more cable.
