Old 10-30-2024, 10:45 PM
Noriyasu Noriyasu is offline
repairment of radiator fan
I made it a new thread.
The genuine radiator fan has been no longer available.
I was asked to repair a fan whose blades were bent and unable to turn.
The wing had melted near the metal part in the center and was tilted at about 3.5 degrees. I heated it with a heat gun, corrected the angle, and then cooled it down to harden.
Old 10-30-2024, 10:50 PM
Re: repairment of radiator fan
I replaced the bearing and trimmed the threads with a tap and die. The bearing part number was 608zz.
The magnet had come off, so I removed the old adhesive and sandblasted the inside. It seems that I can use Loctite 331 as the adhesive. It's an adhesive specifically for motor magnets. It's expensive, but...
Old 10-31-2024, 02:44 PM
SVX_MY_BABY's Avatar
Seems like a job well done.
Peter
Old 10-31-2024, 06:10 PM
The adhesive never hardens. I looked it up and it seems I need a hardening accelerator, SF7387. This is more expensive than the adhesive itself. It's a really expensive adhesive.
