5mt writeup... Finally done
5/6 Speed Conversions for Subaru SVX using custom parts available from TomsSVX
4/19/06 Parts list for 5/6mt swap __ 5/6mt assembly __ 5/6mt shift linkage(be sure to get all the pieces) __ 5/6mt starter(both are the same at least for wrx5mt and sti6mt) __ Helicoil kit for starter stud(late model transmissions) __ 5/6mt slave cylinder(hydro only) __ 5/6mt Master cylinder(hydro only) __ Hydro clutch line (both hard line and soft line) __ Neutral Safety Switch(for pedal box) __ Brake/Clutch Pedal assembly __ Clutch Kit(disk, pressure plate, throwout bearing, pilot bearing) __ Flywheel (transmission specific) __ Flywheel bolts(longer than flex plate bolts) __ Pressure plate bolts __ Transmission mount __ Rear shift linkage mount(stock or homemade) __ Matching rear differential(n/a for wrx transmissions) *If using the 3.90 R180 be sure to obtain a set of rear axles as well __ 2" extended driveshaft(for all 5mt transmissions)(95-99 Legacy 5mt shafts are known to work with minor modification) *N/A if using 6mt __ 5/6 quarts of gear oil __ 4 quarts of brake fluid(bleeding brakes and clutch) 1. Disconnect Negative (-) Battery terminal. 2. Drain transmission oil and front differential oil 3. Remove Intake Snorkel 4. Remove throttle body (You can disconnect cables or simply move it out of the way) 5. Pop off TC bolt cover (small black plastic cover on pass side rear of engine) 6. Remove TC bolts - Using a large ratchet with (24mm or 7/8” socket) turn the crank pulley until TC bolts are visible. - Remove all 4 bolts by holding larger ratchet/breaker bar on crank pulley while loosening TC bolts. 7. Remove starter 8. Remove exhaust system 9. Remove front axles from transmission - Remove roll pin from axles at the joint to transmission - Remove lower ball joint bolt from bottom of hub - Pull lower control arm down away from hub - Pull hub assembly away from car while pulling axle from the transmission 10. Disconnect 2 transmission cooler lines (on driver’s side) 11. Disconnect 2 large electrical connectors on the top of transmission 12. Disconnect shift cable from lever (pass. side of transmission) 13. Remove drive shaft - Remove 4 bolts on the rear differential flange - Remove 2 carrier bearing bolts - Slide shaft out of rear of transmission 14. Place transmission jack under trans and lightly support it’s weight. 15. Remove transmission X-member from body and then from transmission 16. Remove bell housing bolts 17. Support the front of the engine with a jack to be sure it doesn’t fall forward 18. Slide transmission away from engine (this is not as easy as it sounds. This may take a good deal of shaking and prying to break it loose be careful not to harm yourself doing this) 19. Remove flex plate Hey Look!!! The trans is out! 20. Remove center console 21. Remove auto shifter assembly 22. Remove TCU 23. remove SVX brake pedal assembly 24. Remove SVX gas pedal assembly (best off disconnecting cable from throttle body and pulling it through the firewall) 25. Remove brake master cylinder 26. Remove Brake booster ( pain in the butt but it will come out) 27. Install modified/WRX brake booster 28. Pull transmission wiring harness through firewall - Split the harness apart and feed needed connectors back into the car thought the large hole. 29. Test fit pedal box and mark where the clutch master mounting bolt hole need to be 30. Install brake/clutch pedal assembly (top mounting bolts on brake booster will not thread all the way down but be sure they are tight) 31. Reinstall brake master cylinder 32. Cut a piece of sheet plastic to make a plate to cover excess hole from tcu wiring harness behind clutch master cylinder 33. Install clutch master cylinder(may need to trim at the firwall for it to fit) 34. Install modified gas pedal You should now have 3 pedals to brag about. 35. Use helicoil kit to tap a proper sized hole for the starter stud to be removed from the auto and installed into the manual 36. If transmission did not come with electronic speed sensor, swap out the one from the auto. 37. Install flywheel and clutch (you remembered to have the flywheel cut right?? And I am sure you also remembered to buy flywheel bolts) 38. Install 5/6mt (Mostly the same as auto removal) - If using WRX trans disregard the following - If using a 5mt outside of a WRX trans be sure to follow instructions for swapping the SVX carrier into any 5 bolt side plate r160(found at end of my instructions) - If using a 6mt with a R160 follow instruction mentioned above - If using a 6mt with the Sti R180 follow instructions below - Mark the pinion flange nut with a paint pen - Count the amount of threads visible on top of the nut - Remove Pinion nut - Using a steering wheel puller or harmonic balancer puller, pull the pinion flange off of pinion shaft - Install R160 flange onto R180 pinion - Tighten pinion nut back to original mark and thread count - Remove long mounting studs from R160 and install them onto the R180 - Test fit the R180, and mark where it needs to be notched to clear the exhaust hanger - Cut the notch and be sure it clears the hanger - Cut lower strap so that it secures the rear without interference (pic below) - Install Rear axles into hubs - Install R180 39. Install 2” lengthened SVX drive shaft or modified 95-99 Legacy 5mt shaft - For 6mt’s install stock SVX drive shaft 40. If using a WRX5mt or Sti 6mt- Run the two light green wires into the cabin though the hole from the clutch master cylinder. These are to be used for the reverse lights later on. If using Legacy/imprezza transmission, use an ohmmeter to find which wires control reverse lighting by putting the car into reverse and into any forward gear. Find the pair of wires that have continuity while in reverse ONLY. 41. Install front axles and reassemble lower ball joints 42. Install lengthened shift linkage - You must make your own rear mount for the linkage. Pictured below is a good example of possible methods ![]() 43. Attach rubber boot to body in order to keep road noise to a minimum. 44. Install Custom X-member (may require some grinding to open up bolt holes for proper alignment) 45. Connect clutch lines 46. Bleed brakes 47. Bleed clutch 48. Install starter 49. Lengthen speed sensor wiring using heat shrink butt connectors and 3 lengths of wire. - for 5mt transmissions only 50. Reinstall exhaust system. 51. Reinstall throttle body and accelerator cable 52. Splice 2 reverse light wires from trans to…. 2 wires in line with the neutral wires 53. Place 2 female connectors on the ends of 2 lengths of wire. Plug them into the upper neutral safety switch on the brake/clutch pedal assembly. Route the wires over to the auto wiring harness where they will be spliced into the Blue/White and Black/Yellow wires (right next to each other) This will allow for you to start the car when the clutch pedal is depressed. 54. tuck the auto wiring harness out of the way and be sure it will not fall down 55. Reconnect the negative battery terminal 56. Fill trans and rear with preferred gear oil 57. Start her up and be sure the clutch has full engagement and make adjustments where necessary. Be sure the shifter shifts smoothly into all gears . Well that’s about it. Good luck and always remember that www.Subaru-svx.net is an excellent resource so if you run into and problems, the people on this forum will be more than helpful in assisting you. Tom Johnson svxfile's rear diff swap writeup for 3.90, 4.11 and 4.44 applications Quote:
thats all I got in the line of pictures for now. There are plenty more in my locker, just look around a little
Tom |
Great write up Tom! I'm still going to have you do mine... lol
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) ![]() socaleuro.com They like the flat 6... Check My New Homepage.. |
Nice writeup, want to submit to the SVXipedia as well?
well I gave you the revisions from Huck's and they never were able to get posted, so I just said screw it and wrote a whole new one. Pictures are still limited cuz I never took step by step pics. If you would like to list this on SVXipedia feel free but I do not know how to include pictures and whatnot in there
Tom |
As long as you attach the pictures I will take care of the formatting.
Great work, Tom. Thanks. I'll probably be asking some clarification questions in a few weeks
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ![]() ![]() I don't care if Subaru says it's STI...it will always be STi to me ![]() |
Nice Tom, Welcome to the "Ya im that bored so im going to type up a rediculously long but accurate how-to" club!
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
Been there, done that...except nobody read mine
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
Does the cruise control still work the way you have the NSS wired up?
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
yes
Tom |
/Subscribe because I'll need this as a reference very soon.
![]() Anyone reading know anything about "tranny codes"? I guess so we can verify the tranny we are looking at is a WRX 5mt. My friend shipping it I guess is trying to make sure I "don't get ripped off".
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
just look at the clutch fork. If it sits on a pivot ball, its not a wrx trans, if it rides on a 1/2" shaft, then its a wrx transmission
Tom |
Don't ALL the turbo trannies ride on a 1/2" shaft?
Good write-up, Tom... I can't wait to get mine 5MT swapped :-)
