Power steering pump
Its seems awfully loud!! makes like a whirring/whining noise. Mostly when the car is cold. The fluid seems to be alright. Any ideas?
The o ring between your pump and fluid tank might need to be replaced
![]() Mike |
Sounds good!! How do i do it?
NM found it! thanks!
http://www.subaru-svx.net/archive/ar...?message=23386 PS: are you SURE this will fix it? The pump performs perfectly. Never a problem. Just makes a whining noise at idle when i pop the hood on a cold day. |
No, I am not sure as I havent seen the car personally. That is just my recommendation. It is an easy $3 fix you can do yourself, so it wouldn't hurt anything to try it.
Mike |
