Headed to VIR June 13,14
Full course at VIR, So far I will have the only svx. A guy I used to work with says he ran with the mazda guys and they are a pretty laid back group. We are staying at the track hotel..figure about $130 bux a night. We got 4 people staying in our room so that helps out a lot with cost. here is the link to spend $435 to beat your car up for 3.6 hours.
http://www.mazdadrivers.com/09_vir_j...cel_policy.htm Here is what im taking....so far Ive got red stuff brake pads in the front and green stuff in the rear..im not a pro driver so im guessing they should hold up to fading. I have not tracked an SVX yet...guess ill do some reading up... The taillight has been installed since pic
Re: Headed to VIR June 13,14
New driver's will go throught he brakes faster than experienced ones... I went through an entire set of pads when I went to Pocono. Also had some significant fade off the straights. Good luck car looks great!!
Tom |
and thanks!
Now thats a horse of a different color!
Looking good overall. Best of luck on the road and at the track.
1991 SVX L JDM 1992 SVX LS-L USDM |
Brake fluid. ATE Super blue or better. Other wise you will boil. And fade. Bleed the brakes after every 2 track sessions.
If you are an automatic keep it in 2. It will shift automatically only when it reaches 6400 rpm. What tires? Have fun.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Valvaoline Syth. is a much cheaper and very good alternative too. We've yet to have issues but were also 1000lbs less then you are. Bleeding is the key as slade said. I'd think about mounting some stock wheelies with a decent used set of 225 r-comps as you'll more than likely need to replace whatever you have on there anyways at the end of it. Remember, slow is fast!
Got a 5 speed. Tires are Firestone wide ovals 225/40/18. sitting on coil overs, and cooled by pwr rad.
color is maya gold pearl, with some house of colors rainbow metallic thanks im gonna need it..
http://www.mazdadrivers.com/index.html
Time is running out! the event is 74% filled at this point. ANY other tips for tracking the SVX? I think I read at one point the coolant is going to "burp" or spew out on me? Im bringing jack, jack stands, coolant , brake fluid, brake bleeding stuff, tourque wrench, electric impact, dont have any spare tires ....any other input?
You said you have a 5-speed, so you'll have a lot more "Engine Braking" to aide in slowing down,which will help save your brakes too.
Anyone have any input on tire pressures?
Back in the day we used to run 31 ft 33 rr (hot lap temps) but those where on rwd cars.
The SVX is a heavy car and you want to be very careful about rolling over the sidewalls. With ultra high performance summer tires, you want to see a hot tire pressure in the low 40's. The rears should be 3-4 lbs less. Usually your cold to hot pressure rise will be 5 to 6 lbs front and a little less on the rear. Suggest you try the white shoe polish tool. Paint a couple of stripes of white shoe polish on each tire, running from the tread up the sidewall to the wheel. After you come in from each run, see how far up the sidewall the shoe polish is scrubbed off. If it's scrubbing up the sidewall put in more air.
