reversed jumper cables now it wont start
My battery went dead so when I went to jumpstart my car I screwed up and hooked it up backwards. I have replaced the fusible link, and checked all the fuses. I installed a new battery and installed it correctly but it still won't start. All the dash lights come on as normal but the car won't turn over. What should I look at next?
What did you use to jump? Another vehicle? Portable charger? Is it ok or dead too?
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
Isn't the system Diode protected???
ALICE: 2005 Forester XT (Ice Racing Machine) River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment) |
I would check the major fuses or Fuse Link. Good luck and let us know what you find out.
Don't just check to see if any are broken, check to see if any have melted or burned, and check they are the correct amperage.
If the fuse link opened as a result of you applying voltage at reversed polarity, this would indicate that something in line past the link, went solidly to ground. However as the dash lights work OK, it would appear that the short has cleared and was short lived. Alternatively that the short was on an independent circuit. If so and it remains, there should be another blown fuse 4. Exactly what does and does not now work within the complete electrical system? You say that the car won't turn over. 5. Are you sure that the new battery is fully charged and properly connected. If you turn on the head lights while trying to start the car, do the lights stay reasonably bright, thus indicating a good battery and connections? These are valid questions which can assist with a positive diagnosis. P.S. Meantime don't panic and expect the very worst as may be suggested.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 07-15-2007 at 05:09 AM. |
I did something similar a couple years ago... I melted my entire underhood fuse box.... Pain in the ass to troubleshoot when the whole thing is melted together inside... Take a peak at yours
Tom |
I use another battery to jump start. I hooked jump battery pos. to dead battery negative and jump battery neg. to jump battery pos. I have went through the underhood fuse box and checked each side of each fuse and installes a new (subaru) fuseable link. I have checked each side of the in car fuse panel and replaced any fuses that where blown. I installed a brand new battery and it is known good. All the accesories work such as radio, headlights, power windows. |
Okay, so now you need to provide more details regarding what you mean by "it won't start". Is the starter solenoid "clicking"? Do you hear the fuel pump running when you turn the key to On? (I'm assuming it still won't turn over)
-Bill
I hope I am correct in now assuming that the fuse link was blown due to the mishap, as were other fuses. Can you identify the fuses which you had to replace? This could help a lot.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Fuel pump is coming on, but there is no solenoid "clicking". |
-Bill
