A few days ago, my climate control unit shut off. I knew I had to replace it due to the buttons being worn and it randomly changing settings, and this meant that I had to do it. So I took out the old one, tossed in one I bought a few months ago off ebay, and all was well for about 2 days.
Started the car in the morning, pressed the button, and nothing. Phone charger wasn't lit, and clock wasn't working, so the first thing I though was that it was just the fuse. Sure enough, I pulled it, and it was blown. Replaced, ignition on, and it blew immediately. Did it again and it yielded the same results, obviously there was an issue. In addition to this, I've had a recent issue with my main window switch where sometimes I would press it, and it would take a second for the driver window to go down. I figured I'd have to get the switch, posted, but never found anything, so I left it as is. The functionality of all the other windows was fine. Driving this morning, I suddenly found that my window wouldn't open, and neither would any of the others from my switch. I leaned over to the passenger side, and saw that it went up and down, though I tried it again at home and it didn't budge. I searched the site, checked my fuses and whatnot, and can't find jack. I haven't checked the relay under the driver seat, but my seats and sunroof are fine, so I'm going to assume that it's not the issue unless someone else thinks otherwise. I took everything apart again to see if I left anything loose, and it all checked out. So now I have no A/C and my windows don't work, and I'm supposed to drive to my graduation tomorrow like this. Anyone know what's going on? I'm out of things to check, and this is really making me a sad panda. Please advise. |
Re: One hell of an electrical gremlin
Give me a minute to find my post.
And here it is http://www.subaru-svx.net/forum/showthread.php?t=52869 I should ask if your radio works. Also I can't comment on the windows I don't believe it to be a related issue just one that happened at the same time.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles Last edited by Wikedjuggalo; 05-16-2010 at 06:30 PM. |
Find all units in the circuit for the fuse that keeps blowing...
Unplug them one by one why measuring resistance to ground using a std DVOM. Once there is an open circuit or very high resistance to ground, you have found your component that is cooking... or at very least you have found the section of wire that is shorting out. Have you had an alternator failure recently? Tom |
its a huige PITA to remove that... Leave it there.
Really it sounds like your ACC functions have all gone to ****... although the sunroof is working yes?? It does take a bit of time and a schematic to help point out the items in the circuit... But you don't really have a choice do you? ![]() Tom Last edited by TomsSVX; 05-16-2010 at 06:50 PM. |
Oh, and $5 says you don't miss the SVX, do you? lol. |
IIRC removing the cigarette light isn't all that hard. It's removing the wood grain part that's difficult. I had a similar problem, turned out to be the fuseable link on the back of the lighter. If that is the problem, don't get an aftermarket lighter. If you use your lighter at all OEM is where it's at!
I can't imagine the hell you went through figuring that out the first time around man. On a side note, the window issue was simple; 18 years of potholes jiggled the power supply loose. Took the panel off, saw it, plugged it back in, and smiled. Today was a damn good day in that respect.
We all love you too!
![]() Keith ![]() |
