Transmission slipping when cornering.
Yet another transmission question. If it has already been covered, please tell me which thread or which search phrase to use as I can't seem to find anything close. Here goes...
I city-drive with the transmission in 3rd gear and when cornering and giving a bit of throttle my transmission slips out, the engine revs and then catches once I am going straight again. Not cool. This doesn't happen under light, zero G cornering, only when I give a good push. I haven't noticed any problems going straight forward no matter what amount of throttle I give. The floor is open...
'95 Subaru SVX L-AWD 88K miles. |
Other than that, no eye deer. Harvey.
I can eliminate the "picking up the wheel" possibility and also the low transmission fluid theory as well.
During the process of performing a transmission fluid flush (non pressurized type) are there any components in the trans that can be damaged, bent, left out reinstalled improperly or otherwise made wonkee by a mechanic that would cause loss of fluid pressure when cornering?
THEY INSTALLED THE WRONG FILTER AND THE PICKUP IS TOO HIGH! Or they did not install the O-ring on the correct filter. Or you are pulling more than a full "G" and I want your suspention/tires.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 03-31-2006 at 12:58 PM. |
Do you think I've done any damage to the transmission yet?
'95 Subaru SVX L-AWD 88K miles. Last edited by PhatWeasel; 03-31-2006 at 03:30 PM. |
Slipping
Hi Nate, I think Harvey hit it right on the head. I had a fluid change on my "92 and when I went around a corner it silpped. Called the dealer and he said bring it back and we will fill it up. They did and it stopped. I would check the ATF level. Take care, BOBB
