My car stalled and died
Came out from a roundabout and started a small hill climb, engine cut off and all indicators/lamps lit up, just as they do when you turn on ignition but do not crank the engine (when starting).
Restarted it, and managed to back up for about 200m. Died again. Managed to restart it and land in front of my garage. Pushed the car for 1 1/2m so it doesn't block neither neighbour or traffic. ![]() I might have heard some coughing before it stalled. My main suspicion is either out of gas (i thought i'd make it home, lamp had been on for about 70km. or flat battery. I will pour some gas tomorrow. There was still light, alarm is working. Can the battery still be "daed" ? When I pushed the car i had to turn the wheel. It locked. How do I unlock it? I didn't try too hard but apparently i can't turn the key anymore?! Any clues?
I got my girl, I got my glass, I got my car and I'm ready to f... |
Re: My car stalled and died
Ya they run better with gas. You have a gas pump at home?
![]() To turn the key hold the tension off the steering wheel lock by turning the wheel slightly left and right. |
I believe it was probably a gas problem as well. 70km is about 43 miles with the light on.
As for unlocking the steering wheel and ignition lock, turn the wheel in the same direction as you were before it locked and hold it there. This will relieve the tension on the ignition lock and allow you to either remove the key or unlock the wheel so you can turn it manully. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Mine did that 3 times before I replaced my MAF . Sounds exactly the same way mine acted. Always did it when I turned the wheel. Backed out of a parking space. Going around a corner. After it cools down for 5 min it started right up.
You replaced the MAF because you ran out of gas 3 times?
No my car stalled and all the lights came on and it refused to re start right away. Why do you think he is out of gas? I do not read where he says anything about the gas gage being low .you know what ASSUME Means right. Except leave Me out of it.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by Conn SVX; 12-07-2012 at 12:22 PM. |
![]() Quote:
![]() ![]() Anyway, learn to take a dang joke... Your anger apparently impairs your comprehension and reading skills. |
Rather than charging batteries, pop the hood etc I just poured some gas on. Engine didn't crank at all. Then it cranked and started up with no problems at all.
Will the wheel lock induce a start lock? Was it perhaps only my ****ty after market alarm start lock that interferred? All is ok ![]()
