Thread Tools | Display Modes |
Could blowing the fusible link in the lighter cause other fuses to be comprimised?
This morning, 5 minutes into a 4 hour trip, my climate control system, the clock and the power mirrors stopped working. Last night, while inflating a very under-inflated spare tire, the cigarette lighter stopped working and a little trouble shooting pointed to the fusible link in it. Is there a larger slow blow fuse that feeds both the lighter and the A/C system that could have been weakened in the process? If so, which one is it?
On a related note, the 20A cigarette lighter fuse under the das is NOT blown! That is what is so baffling. The closest case I found to this is here: http://www.subaru-svx.net/forum/show...ter+a%2Fc+fuse But the guy that fixed it claimed the fuse blew even though he never personally observed it blowing.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 06-19-2012 at 08:35 PM. |
Re: Could blowing the fusible link in the lighter cause other fuses to be comprimised
Tony,
See my post in THIS THREAD The exact same thing happened to me. the fusible link went, but not the fuse which controls that circuit. I had no other electrical issues that coincided with it. I replaced the fusible link with a piece of heavy-gauge straight wire. I normally would not do this, but I only use the lighter socket for very low current items, like my cell phone, and my plug-in voltmeter. Will never use it for a high current (heat) item like a cigarette lighter.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-28-2017 at 11:11 PM. |
Also check to see if your sun visor lights are working. Broken wires inside short out and cause a failure of the circuits mentioned. you can remove the visores to see if they are broken up my the hinge.
See the post below. it is accurate and informative. I found this condition and the same symptoms in my son's 1992 pearlie. http://www.subaru-svx.net/forum/show...70&postcount=1 This was my solution, which was less involved as the break was up high and easy to get to. http://www.subaru-svx.net/forum/show...08&postcount=8 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-19-2012 at 09:18 PM. |
That last link was interesting because his fuse wasn't blowing either. Maybe a partial short is dropping the voltage enough to shut stuff down?
So this problem is back. When this originally happened, I replaced the fusible link with a solder bridge which is, technically, a fusible link. I also disconnected both visors. 2.5 years later and my climate control system is wigging out again. This time is just randomly goes dark and randomly comes back on again. No fuses are blowing. The clock, 12V outlet and climate control go dark and come back and either can happen after random lengths of time driving the car. I replaced the 20A fuse under the dash. No change. I replaced the 10A fuse in the engine compartment today. We will see if that helps. Any other ideas?
Just curious, do you have an aftermarket stereo? Mine did this years ago and replacing the cigarette lighter with one from the junkyard and redoing the stereo wiring fixed it.
Check fuses 2, 3, 17, and 25. They all seem to be connected at one point on the schematics. Is the radio or the wipers affected?
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 01-19-2015 at 08:01 AM. |
If all else fails, check the wiring between the Clock, Lighter, Vanity mirrors, Power mirrors and A/C Control unit. They all connect to each other to breaker #3, its the green/red wire. You may have a loose wire not making contact or shorting.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
Radio is a Pioneer. It does not go dark when the clock and climate control do.
I agree with dannmarr, check your wiring. I just recently had the fusible link blow behind the cigarette lighter, but have not hany any other electrical issues as a result.
A couple months back I would get an occasional dimming out(to complete off) of my HVAC, and clock. When I did the alternator wiring configuration V4 the issues resolved. So it was just a matter of making good clean grounds as I did NOT replace the alternator with a High Output one.
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
