Need help! I have a knocking sound!!!!!!!
Re: Need help! I have a knocking sound!!!!!!!
Sounds just like mine that had a spun rod bearing right before it blew up.
![]() Sorry, don't mean to scare you.
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
Sounds like mine like almost all the time. Normally I just add oil and it stops.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k ![]() |
Make sure your power steering pump is full of fluid. If you have a leak and it is dry it can make an extremely similar noise.
Hopefully it is not a bearing... good luck.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
You think its the PS pump?! I figured it would be a heat shield or perhaps and bent rod....
Kieth,
Yes it is quieter. My buddy mike (audi guy) says it sounds like a lifter as well. If only I knew wtf that was exactly!! lol ![]() (though now that my dad heard it, he doesn't think it is a lifter at all. Though it is an engine noise... hope i can get it resolved soon) Last edited by XxMattrimxX; 05-16-2011 at 06:36 AM. |
You ever figure out what your noise was?
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
Oh and the PS res is full. Im no fool. I keep all fluids at peak and check them regularly.
What octane fuel are you running and when was your last oil change? What weight/brand oil. As of now I see Seafoam in your future
Kinda scaring me a bit lol!
My last oil change was <1500 miles ago with a 5w30... quaker state? ...high milage half synth (to see if it smoked at start up still, otherwise its full synth) and I uses 91 premuim at QuickTrip only! What is Seafoam? Is it expensive? (edit: looked up seafoam video http://video. ![]() Last edited by XxMattrimxX; 05-08-2011 at 06:22 AM. |
5w30 is probably your problem. Should look in a recent oil weight thread wherethe best suggestions for oil in our car were made.
Also, I used seafoam in my car and nevr listened for the knocking or if it went away after that. It may have.
Hey I know the weight differences and what they are good for, but i changed the oil twice in less than a month because i did the first one and then had to replace the valve cover seals along with oil again. It was still cold cold when I put the oil in, and it got to -11 in MO this winter. with a **** ton of snow too lol. pic as proof:
No change between gears or directions. Only when warmed up does it stop.
LetitSnow - What was wrong with the engine you recently pulled? Im looking for that sort of speculation here. |
Sounds like mine does right now, except louder. When you start it from cold (overnight type thing) does it make a horrendous racket for a half second or so? If you have the tools and know-how, drain the oil and look at it. If it's a silvery metallic colour then you're definitely in the same boat as me, which is that you've lost a bearing in one of your connecting rods. The simple fix is a new engine.
I didn't crack the engine open to see what was the problem, partly because of time, but mostly because it sounded a lot like what I've come to know as rod knock.
