Subaru SVX parting out
Hi everyone,
So im unfortunately going through the process of parting out my 92 green Subaru SVX. Here is a list of the parts ive got out now, if you dont see it on the list I probably have it just havent taken it off yet so please pm me and ill see if ive got it. I will update this listing has things are sold and as new parts are taken off the car. 1. Engine 2. Wiring Harness with fuse box 3. Ecu 4. Dashboard 5. Center Console 6. Drivers side headlight 7. Drivers side door with glass and interior panel 8. Drivers side front fender 9. Passengers side taillight 10. Center taillight 11. Carpet 12. Grill 13. Stock CD/AM/FM/tape player with metal casing 14. Hood shocks 15. Rear windshield wiper motor, arm, & seal 16. Interior side pillars 17. Oil cooler 18. Coolant reservoir 19. Passengers side window regulator 20. Passengers side door handle 21. Passengers side door lock mechanism 22. Steering Column 23. Airbag control unit 24. Horn assembly 25. ABS braking assembly 26. Under dash strong beam(reinforcement bar) 27. Plastic floor sides 28. Heater blower 29. Heater core 30. Cooling unit/core 31. Drivers side front upper seat belt motor and track 32. Passengers side front upper seat belt motor and track 33. Drivers side bottom seat belt 34. Passengers side bottom seat belt 35. Window wash reservoir (front) 36. AC liquid tank and pipe 37. Wiper control unit 38. Day time running lamp unit 39. Shift lock unit 40. Timer control unit 41. Door lock timer 42. Security Module 43. Cruise control unit 44. Hood latch 45. Bumper reinforcement (front) 46. Passengers side airbag sensor 47. Power seat belt control unit 48. Front bumper cover (isn’t torn but has some scratches) 49. Gauge cluster 50. Dash switches 51. All the dash parts 52. Front cowl 53. Front windshield wiper motor, mechanism, and arms 54. Drivers side (side skirt) 55. Drivers side airbag sensor 56. Rear passengers side seat belt 57. Rear drivers side seat belt 58. Rear bumper cover no tears some scratches 59. Rear bumper reinforcement 60. Trunk lid with stock fin 61. Trunk shocks |
Re: Subaru SVX parting out
i need the rear end...
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
is it an LS-L? do you have a drivers heated mirror??
I would be interested in the following parts:
The trunk shocks, a rear wiper motor, the RF hub assembly. Could you please PM me with an estimated cost (including shipping). THANX |
How much for the engine? How did it run before you decided to part it out? Any oil leaks? Valve tick? Hesitation? I am close so I could come pick it up. My project has been taking so much time and money, I just want my car back
![]() EDIT : how many miles?
