ABS Computer control unit - anyone??
Does anyone have a spare ABS control unit that sits under the passenger seat???? I need one urgently as mine got fried when heater core burst and drowned it with coolant!!
Re: ABS Computer control unit - anyone??
picture of old one please with some numbers for clarity.....
Here are a couple of photos of the unit - hope it helps in locating one.
I've got one
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
see you can sell anything with a photo -
Have sent you a PM - please call me so we can work out details.
Do you by chance have one???? So far I have had 2 incorrect units sent and one identical but unfortunately on test came up with the ABS warning light so not good.
I am getting a bit desperate!!! |
I have one here from my JDM parts car.
Various stickers on it read : 48 RHD 4WD AT Nippon ABS 26720pa010 (probably the Subaru part#) 170-0701 (probably the serial number) Condition unknown, but I may be able to test it in my DD. I've pulled the cover off and it looks clean & tidy inside. Any idea of it's value ? |
Thanks Shane - that is the part number of the unit I need. I am in the process of bidding for one from Japan which will cost me just over $100 landed but will probably take another 2 weeks. If you can plug it into your car just to see if no ABS warning light is triggered, we'll at least know whether the unit is OK. At least that way I know where there is one.
Thanks again for your help! Andrew |
Probably not until this weekend. I assume I need to remove the passenger seat then follow my nose from there.
No error light on the dash or do I need to also check the light hidden under the passenger seat ? |
