Radiator crack...
Anyone had any luck patching the inevitable crack that appears on original radiators under the filler neck after a while? I've heard epoxy, JB weld, etc., but is there any trick to the application to make it work better/hold longer?
Re: Radiator crack...
drill a small hole at each end of the crack to hopefully stop it from continuing to spread. Prep the surface by sanding to give whatever your using something to bite on to.
What Dave said plus replace that upper rad hose and check your motor mounts for excessive play.
JB marine weld works pretty well. I didn't drill holes in mine but I sanded it with like 50 grit sand paper. Lots and lots of sanding. You want it really rough.
Then I used two applications of JB weld. First about 1/8 in thick and the second (sand again beforehand) about 3/8 thick on top of the first layer. Basically I filled up the indentation in the plastic radiator top to make it have a square corner. It lasted about 6 months until I bought my aluminum radiator, so I was pretty happy with it. Make sure to let the JB weld cure for long enough.
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
Or bite the bullet and buy a new one for $131.80 shipped.
http://www.ebay.com/itm/1992-93-94-9...m=120837762868 |
![]() Keith ![]() |
