Old 09-15-2006, 10:56 PM
subru92svx subru92svx is offline
Send a message via AIM to subru92svx
4.44 gears
I was just curious how hard it is to do a 4.44 swap? I have a guy whos willing to sell me a 1998 forester tranny and rear diff with 4.44 gears for $300 will that one work? Do you pretty much just swap out front and rear differentials? I take it the car feels a lot better with 4.44 gears? Any info would be great. Thanks
Old 09-17-2006, 08:23 PM
If it's an early 98 tranny it wll work...you can tell by looking to see if it has a screw on filter on the drivers side of the tranny case...if it does have the filter it's the newer versin of the tranny, and won't work...no filter, means it will work.
It is a direct bolt in replacement for the SVX tranny, just have to swap the 4.44 ring and pinion into the SVX rear diff to retain the LSD, and use of the SVX rear axles.
And YES It will feel MUCH better with the 4.44's
Old 09-18-2006, 02:02 AM
Well the transmission the guy is selling is slipping in a few gears. So could I just use my transmission and his front and rear differentials? If the transmission is the newer one with the screw on filter with the differentials still work on my trany? Thanks
Old 09-18-2006, 05:27 AM
That I don't know....
Old 09-18-2006, 04:14 PM
NeedForSpeed NeedForSpeed is offline
tomsvx posted that the front gears are not interchangable on the newer design. If the same design, the front diff can be swapped onto your svx trans. Read the thread or search svxfiles posts to get info on installing the lsd into the donor rear diff.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 09-19-2006, 06:06 PM
Ok well heres my next question. What is a better setup the 4.44 or the 4.11's? I've seen members have both and thought I'd try to get a little feedback before I decided. Thanks
Old 09-19-2006, 06:13 PM
In my experience 4.44s have lasted longer, and have better first and second gear ratios!
Old 09-19-2006, 07:24 PM
It depends.
If you drive flat terrain at freeway speeds and above, go with 4.11. If you drive hilly terrain at variable speeds 60 and below, the 4.44's are unbeatable. If you are interested in max acceleration, listen to svxfiles, he knows.
Old 09-21-2006, 09:07 AM
Hey look!!! someone listened!!!
Old 09-21-2006, 05:07 PM
What? You think no one listens?
Keep setting the pace, we're here!!
