A/c vent issue
I have a problem with my climate control, everything works fine except I can't
Get any airflow to come out of my vents ( dash vents ) it switches fine between floor and defrost and auto temp function works fine. I'm going out later today to check for codes but was wondering if anyone else Has run into this. Thanks. |
Re: A/c vent issue
There are a couple of linkage things on the unit under the dash and one of them could possibly even become loose/sticking. maybe try to "stand on your head" and try to see what is happening as you try different settings?
Good luck, Keith |
Re: A/c vent issue
The doors are controlled by sliding arms which are held together at their pivot points my machine screws.
I had one of these screws unscrew itself and fall out. I found it under the floor mat. I looked under the dash and could see the hole where the screw was, that connected the two arms. One lever would move, but the other was not connected to it. Replaced the screw, added a bit of LocTite and all was normal again. Hope your fix is as simple. Also look at THIS THREAD for diagnostic procedure (post 4) and photo (post 6) .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-25-2012 at 11:12 AM. |
Re: A/c vent issue
Keith |
Re: A/c vent issue
I had an airflow actuator motor fail with a result pretty much the opposite: Nothing out the floor vents nor defrost. (Don't remember if any there was any output from the dash vents.) Don't much about such workings, but the offending actuator in this instance was outside the airbox on the passenger side, high on the tranny hump. You might start by modulating the heat/AC control and observing this thing for a full range of movement. (Could be there's another actuator that controls the dash vents.) I was able to troubleshoot with help from this forum; if you haven't, you might search for more detailed info.
dcb |
Re: A/c vent issue
I have a dead mix motor on mine. The one on the drivers side. I don't believe it is possible to replace it without removing the dash.
Re: A/c vent issue
Been there... No easy way... Keith |
Re: A/c vent issue
Especially if you have progressive bifocals and what you need to see is not in focus unless... my head doesn't tilt back that far
Re: A/c vent issue
Would love to have a "how to" video of someone trying it! Keith |
