rad fans stay on
i've noticed lately that my rad fans dont turn off at all now, what would cause this
Re: rad fans stay on
Your fan sensor . I believe it is near the bottom of the radiator . You don't have the climate control on or the defroster right
Fan sensor? Really?
My old 83 had one at the bottom of the radiator .
CONN 83 WHAT? In my case its always been the coolant temp sensor. Happened in my legacys and my prior svxs
It was an 83 GL wagon. You call it a sensor or a what ever It is in the coolant and when it gets hot it turns the fan on . So chastise me for calling a FAN sensor .I stand corrected it is a coolant temp. sensor
Coolant temp sensor is a possibility.
i second that. after moving around stuff in the engine bay my fans were staying on and it turned out to be the coolant sensor connector had come off.
if thats the case couldnt the engine temp gauge on the dash not work either? mine still shows hot and cold
it has two sensors, one for the gauge and one for the computer
No, there is one for the ECU which controls the fans and the air/fuel mixture, etc. and there is one for the gauge cluster.
Is your speedo functioning normally?
