Air Cond. Service >>>>
I'm at the mechanic getting my AC serviced (sucking out refrigerant, then filling full). The cross bar in front of radiator shows R - 12, but the fittings and compressor say 134.
My question is: HOW MUCH 134 SHOULD IT TAKE TO FILL? [The R - 12 label says 21 to 25 oz., but the dealer mechanic says around 32 oz. (?)] Please give me your opinion if you have info about this, THANKS! ![]() ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
