fuel injectors
I was reading some ware that the fuel injectors used on the svx motor are the same as the ones used on other 2.2 Subaru engines.
Is this right? If so after market injectors would fit svx motors.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles ![]() My WRX's Cardomain Page |
I though the Nismo injectors would fit from a Q45 or something?
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
so is there any one who could find out if older 2.2 subaru motor injectors would fit.
I think the 92 legacy trubo injectors have a higher cc then the stock SVX injectors.
well I got the part number for the svx injectors
16611AA310 from www.subaruparts.com www.1stsubaruparts.com lists part # 16611AA310 as fitting Forester 1998 Legacy, w/o Turbo 1992 - 1994
i heard you can swap in legacy turbo injectors for the na 2.2 liter.
So I guess thats a yes then. Well thats good , if I do trace my starting hesitation down to my injectors I have like 8 spares I could use.
now that we know the SVX and legacy injectors are the same.
What would hapen if I put turbo legacy injectors in my svx? would I get to much fuel in to motor or would the ecu shortin the pules and ajust to the bigger injectors. Not that I would do this any way. I just don't know anything about motor moding and I don't want to messup my car.
The idea behind upping the fuel pressure instead of installing larger injectors is that the higher fuel pressure causes the injectors to spray a finer mist. But I have a question for you. You've got an a/f ratio meter on your car. Does it read rich, stoich, or lean at WOT?
I don't know the gauge goes blank at WOT. I have not found out why yet.
