Is the new radiator any better than the original? Is the plastic top still prone to cracks? I searched this site but found no answers. Is the most affordable place to buy from still LibertySubaru.com? Did anything come from the people talking about aluminum radiators?
Thanks in advance... |
Considering the most of the radiator problems seems to be on 92's, they've lasted 10 years.
If you put in a new replacement, and get another 10 years, I certainly would consider it money well spent. ![]() I wonder if it's worthwhile for those with 92's right now to re-enforce it somehow before it cracks. VK |
radiators
Mine's a 95 and she's got a crack in her. I've been looking at going with a unifit aluminum rad or trying to but at this point I'd rather spend my money on a new timing belt and all that good stuff underthere. That way a new radiator doesn't have to go through the punishment of changing that stuff.
I don't know if the top of the new radiator is made up of a different composite material than the original. I replaced mine about 6 months ago and externally it looks exactly the same
The main improvement was the removal of the fine mesh screen in the internal transmission fluid cooler. It modification is supposed to improve flow and eliminate the clogging that bugged the early models.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Why not just get an aluminum radiator? I know they're pricey, but considering how $$$ svx parts are to begin with I don't think it'd be that much more, would it?
- Ca$h |
I just tried to find a post someone sent me when my radiator died but I can't find it. They said they bought a brand new Toyota radiator over the net for about half the price and it was exactly the same as the original.
I use Liberty Subaru as it is close by to where I work. |
Re: radiators
When you change your timing belt the best thing you can do for your radiator is remove it--plus you have better room to work on the front of the engine.
![]() Quote:
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! ![]() |
Re: Questions for those with NEW radiators
An SVXer was going to have a radiator made by them
I remember e-mail with this fellow, and from what I had recall, it wasn't an exact fit, but he fab'd it somehow. It was for a Celica, I believe.
VK Quote:
Re: Re: Questions for those with NEW radiators
Thank you for inquiring with us at Griffin. Your Subaru radiator would be a custom design for our company. In order to produce or quote you a price, we need an original sample or a drawing of the radiator sent to us with all necessary dimensions. ---------- Anyone know where I can get a good drawing with all the specs? |
Re: Re: Re: Questions for those with NEW radiators
John |
Phone: 1-800-722-3723
Fax: 864-845-5001 Griffin Thermal Products 100 Hurricane Creek Rd. Piedmont, SC 29673 |
That's a ways a way. If Larry III comes to Kelli's this weekend I can pass it to him.
Anyone south of Delaware that could pick it up from him? |
If you have an old one you could just measure it. They'd probably need the general dimensions and where the radiator hoses attach, along with the diameter of the hose. And how it mounts. I couldn't see them really needing anything else.
- Ca$h PS: A cheaper way would be to look for a car with a radiator similar to an SVXs, and just order one from Griffon, and mod it so it bolts in somehow. :| Custom is $$$. I know a guy who had one done for his neon. |
I spent some time at a salavage yard looking for one. The guy said that the hose connection is 'Unusual" at the top as it comes out at an angle.
I would rather send it to them so they could match it up, tube number and all that, also the tranny cooler. I noticed that the svx radiator is thicker than most others I looked at. The mounting stubs also have to be the same so that the rubber bushings can hold it in place. |
