RHD to LHD Conversion
Sorry if a thread is posted somewhere, but I did a search and couldn't find anything. Has anyone done a RHD to LHD conversion? Is it even possible/ Approx costs/time assuming one has the obvious parts (a great condition, low mileage Japanese RHD, and a limping LHD). Any other comments, issues welcome. Thanks!
Re: RHD to LHD Conversion
You mean actually move the steering wheel and pedals to the other side of the car? The work would be massive. Other than the general nuts and bolts, I suspect the firewalls are different. Different holes for steering wheels, etc. Cutting out one firewall and welding in another is going to be a massive amount of work.
So off the top of my head: -Swap subframes, and steering racks. -Swap firewalls -Brake booster/master cylinder -A/C System (I bet the lines go through the opposite side) -Entire dash, including interior A/C, heater core, etc. -Move ECU to correct side (may require extending wire harness to fit, or swapping in LHD harness) -steering columns -Pedals -Center console, shifter, etc -Headlights -Rear View mirrors -Window controls on the doors (would also mean you get to change out those harnesses as well) -Seats, if you want to retain the power drivers seat. Again this means swapping wire harnesses, and in this case pulling up the carpet to get at it. -Trunk lever/Gas door, plus it's cables that run to the back of the car Etc. Basically you're rebuilding the car from the door handles forward. I should add it's generally considered sacrilege to molest a JDM car like that. However, you could take what you need to repair the LHD car.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 02-15-2011 at 01:03 PM. |
