Idle fault
The fault goes like this :
When in Drive with foot on the brake the car idles perfectly. Push the transmission into Neutral or Park position the engine idle swings between too high and too low. Also most of the time the check engine light comes on. All suggestions are welcome. Video posted here : http://www.youtube.com/watch?v=XuAjfoj6Xok |
Re: Idle fault
This seems to be a common problem with SVXi lately, my issue didn't go away yet and I am pretty sure it is caused by ICV.
I assume I only need to remove the throttle body to reach the ICV? If so, how shall we clean it? I've heard it is a very sensitive part to clean, a strong solvent will risk damaging it on the inside.
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
Re: Idle fault
Re: Idle fault
What is ICV ?
Re: Idle fault
SOLVED: Idle fault
As I suspected, removed the ICV today and had it cleaned with Carb Cleaner then Electronic Contact Cleaner, and put it back together. Car is AS NEW again. The idle stabilized as it should and I am extremely happy now.
