SVX Key Fobs
6 SVX Key Fobs - may work, may not - make offer
Re: SVX Key Fobs
Are these the ones on eBay ? If not, more details maybe..clickers work, internals corroded from old battery..? Pix would be great. I am interested, not just wasting time.
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod. |
Re: SVX Key Fobs
Ive asked for internal pictures of the ones on eBay and the seller never complied. Hopefully these turn out decent.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Re: SVX Key Fobs
Some of the common problems with the used ones are....plastic flap with orange dot hinges are broken, metal spring wire on neg. battery side soldered joint broken, internal button for pressed flap doesn't "click", plus the electronics are bad just cuz or from battery corrosion seepage.
Re: SVX Key Fobs
These are not on ebay. Will provide more info as I examine them more thoroughly and will see about sending pix.
Re: SVX Key Fobs
Great, much appreciated...
Craig
