Old 11-03-2007, 04:15 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
Antenna motor dead?
My antenna quit on me about a month ago, and I just got around to pulling it out. It has power to it, just won't work. So I bench tested it and the relay clicks, but the motor does not turn. Is this a dead motor?
-Nate
'92 LS-L Pearlie
Old 11-03-2007, 04:25 PM
Trevor's Avatar
Trevor Trevor is offline
The relay contacts could be faulty and the motor OK.
Trevor, New Zealand.
Old 11-03-2007, 07:34 PM
Sir. Nate's Avatar
SVXtreme
I took it apart and cleaned it, but it still doesn't work. I'll probably end up buying a replacement.
-Nate
'92 LS-L Pearlie
Old 11-03-2007, 11:45 PM
Trevor's Avatar
As a test try applying voltage directly to the motor. Sniff about, use your noggin, work out how it works, it could be fixable.
Old 11-03-2007, 11:49 PM
Trevor's Avatar
As a test, try applying volts direct to the motor. Follow your nose, work out how it operates, it could very well be fixable.
Display Modes
