FS: All parts including Glass!!
I'm considering parting out my 92 SVX LSL. It does not currently run and honestly, It's becoming such a headache.
Known bad parts: Driver side front fender- rusted though in 2 places driver side window switch will not control pass window Wheel bearings all around hood props trunk props pass side view mirror cracked Parts known to be good after testing for no start issue: MAF Coil packs Fuel pump Injectors crank sensor Just replaced parts (less than 500 miles on them): Radiator ABS unit front half shafts Make some offers, if I can't sell enough parts almost immediately, I'm going to keep working on that in the world is keeping it from starting. Also open to selling the whole car, it's in Rochester NY and I would need more than $1200 to make it worth not parting out. Thanks! ![]() |
Re: FS: All parts including Glass!!
I think I am going to need an A/C compressor soon.
Wait for it...
Is that an OEM radiator? I'm interested in it as long as it won't crack or leak for the next 10 years
![]() P.S. what condition is the driver's seat in?
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
Whats your offer on it? |
It's not from the dealer or anything, no. But it is OEM specs... it better be for what I paid for it. and drivers seat is in decent shape, no rips at all.... a little cracking though... what can i say, its old leather. |
Is it the original compressor? And how new are your struts? Same for the fuel pump? I get an odd gurgling noise when I first turn the key.
Front half-shafts-- OEM Subaru or someone else?
that's normal...
It's supposed to make that noise.
Struts/springs/mounts are all good Fuel pump good too - checked for fuel pressure when we tested the no start issue - On the comments about a gurgling noise being normal... I've never heard it... |
Bought the half shafts from advance- paid $100 each after shipping
I'm just wondering if it has the same 20 yr old brittle plastic as the original ones.
I should have been more precise- The radiator is a new aluminum rediator, not plastic
And back to the struts, are they also the original struts?
