#211
Re: Power Mode Selection
You guys might think I'm crazy. Let me explain:
When I bought my SVX, it kicked A** When the Trans was rebuilt, It wasn't as good. When I swaped it for a 4.44, it was better, but not like the original. In other words, it has never been the same. Now with the power mode, It kicks A** again! I could swear that the original trans was just as strong as in power mode now. Am I just imagining this?
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#212
now imagine the original transmission with power mode!
now that is something to blow your mind. |
#213
dannmarr - I have a 4.44 in my car also, and I felt the opposite of what you said happened with yours. the 4.44 improved acceleration, and that general power feeling using the butt dyno. What torq converter and TCU did you use when you did the swap?
Remember the stock trans was a 3.54 and you put a 4.44 in, so you went from a top end transmission to an acceleration transmission. I think what you are noticing is the difference in where the power gets used on the EG33 engine. I makes its peak power from 3500-5000 and seems a bit flat between 1500-2500 (At least my 92 does, always had even with teh 3.54 in it) Sorry if this **** dont make sense, been up all night.. gotta love insomnia
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car 86 Lifted GL wagon well over 600k miles on the chassis 98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires |
#214
Anyone with a 4.44 got an 60-100mph wot video? 14secs from 60-100 for him, 11secs for me. The 80-100mph that is WAY slower in that video.. like 3 secs slower... Takes me 5secs, takes him 8secs... |
#215
I found out why my car wasn't as powerfull as it was before. A bad coil
![]() Front, driver side. Amazon sells the front coil for $120. Anybody buy from them? That is the cheapest I found.
#216
subaruparts.com is about $80 for an OEM...
#217
Thanks for the quick response! Subaruparts is $95 with shipping charges. Last last two orders I made with them took much longer than they said. Amazon says it will be delivered on Monday with free shipping. Hard choice, time or $?
#218
I replaced the coil and what a difference! I also soldered the power mode connection directly inside the box. It kept falling out of the slot. Don't have to worry about it coming loose.
#220
Just posting to say I dug into my photos and found the ones I used for this thread, reuploading them to imgur. All the photos in the first post should work now.
#221
a little bit of a bump, wondering if anybody has wiring pinouts or such, would like to disable my parking light switch and turn it into a power mode switch.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#222
Based on the wiring diagram that I have, the switch connects "fuse block pin E8" to "fuse #21 (F/B pin D11) " or "red-wht" to "blu-red" Hope you can find the wires
DIY FTW! 1993 SVX 25th Anniversary Edition @+142k -Rebuilt Tranny @135k -Regasketed Engine @140k -Enkei Raijin 18x8.5, with 255/35/18's @140k -BC racing Coilovers (From STI's) @142k |
#223
just curious , i tried to wire in the power mode mod (didnt work)
im a little confused seeing as the pictures are lhd and mine is rhd is the plug in the same spot (lower most plug of tcu) or ? the plug i pulled is a 20 pin plug with the 4th one being the only empty slot |
#224
![]() I have a ROM fitted that has the Economy map replaced with the JDM power map, that works better that the US version, that is only an acceleration map. Harvey.
#225
i know the jdm ones have the power mode button and the uk ones have the economy button but ours have neither of them so how does the power mode engage on the aust spec ones (mine is weird it works most of the time under 80 kph , but no matter how many times i mash the pedal wont engage over 80 ) is there some other way to make it come on without the rom |
