Power Steering Pump Bearing?
Looking through the how to documents as my power steering pump is showing symptoms of a noisy bearing.
Part 31263GA840 is discontinued, and I am trying to find information on a suitable aftermarket replacement. Thanks in advance.
1991 SVX L JDM |
Re: Power Steering Pump Bearing?
Took my core PS pump apart tonight.
OD 35mm, ID 15mm, 11mm width are the specs. Ordered some timken bearings that match the spec of the NTN that was in place. https://www.amazon.com/TIMKEN-15x35x...l%2C157&sr=1-1
1991 SVX L JDM |
As you know, size are d=15, D=35, B=11 If available, I recommend to you also replace the front and rear oil seals. |
34481 31263GA840 Ball bearing, power steering pump => use 6202LLB instaed 34488F 34424AA000 Oil Seal Pump 34488A 31263GA890 Seal O-ring 34488B 31263GA900 Seal O-ring 34486 34437PA000 Lock pin pump discontinued 34482 34425AA000 Gasket pump discontinued 34418 34432AA000 Spring Canceled 34488B 34427AA000 Seal O-ring discontinued => use Third-party product Inner diameter 13 Thickness 2.5mm 34488C 34427AA010 Seal O-ring 34415AA051 Connector/Pump Assembly Discontinued FYI |
Thread Tools | |
Display Modes | |
