#2671
Got my brake line fixed & rerouted. Thanks to the guys in this thread http://www.subaru-svx.net/forum/show...ake+line+route and particularly to dannmarr for the photos.
Also just for fun: ![]() ![]() ![]() ![]() ![]()
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
#2672
Just a heads up to say the $68.00/pair front axles on Amazon (+ S/H) worked great, thus far. They seemed a bit short when compared to the old OEM axles but when I pushed the old CV's together they were identical. The new roll pin has a chamfered end, BTW, which goes in first, but no chamfered holes on the diff side. There is a chamfered hole on the stub axle so that should be the "down side" with the correct roll pin going in. The grooves on the new axle had the identical one hole with groove going down its middle and other hole with 2 grooves straddling the hole so it lined up perfectly first try.
The new roll pin insertion technique I used was to take a punch, insert a 3/4" piece of hose over the end and insert the roll pin..I actually had to slip a smaller diameter hose piece on the pin which I then put in the larger diameter hose on the punch. The rest was the usual..32mm axle nut after removing the dust cap, tie rod end (I didn't put the other wheel off the ground plus with the tie rod off, you get more slack/movement with the spindle, strut side of sway bar link, lower ball joint, ABS/brake line strut holders. Brakes left on.. Let the lower ball joint stud go to the front side of the spindle, turn spindle as in rt. hand turn for ease of axle removal, and reinstall. Remove roll pin from non-chamfered side. I put a dab of silicone on the new pin sides to keep out corrosion but doubt I'll have to mess with new axles for a while. I tried putting axle first in diff side and then first in spindle side..putting the axle in the diff side went more smoothly. Could turn axle more easily to line up holes plus, if spindle side went in first, it kept popping out anyway as I maneuvered the diff. side. Last edited by fasteract7; 09-28-2015 at 03:51 PM. |
#2673
Swapped out the timing belt in the Legacy. All I can say is, the SVX is cake by comparison. Pain in the ass dealing with those DOHC pulleys, the SVX geared cams make like so easy!
#2674
Addendum...noticed the steering had that "sorta didn't want to turn" feel and checked camber/toe..Camber still at my -1.5 where as I now had a bit over 2/32" of negative toe. Quick fix and steering nice and neutral. Would suggest the new axle is not perfectly perpendicular to the spindle/hub assembly either secondary design of car or tolerances of new CV joints.
Changed battery as car would not start - new one cost me NZ$200 - it was approx. 20mm shorter than the old one, so ended up requiring a spacer in order that the cross brace piece could clamp correctly.
The old battery was 18 years old !!!! so lets hope the new one lasts as long....
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
#2676
Had a busy day with the '01 OB 3.0. Spent a while tracking down a CEl, didn't find the problem, so I replaced all the light bulbs on the HVAC control. Then it wouldn't stay at all, spent about half an hour before finding the fuse for the ECU was blown.
Then a couple of hours after I was driving around and the exhaust dropped... It does have that nice sound like an un muffled SVX, but I decided to fix it right away and got to spend a few hours contorting myself under the car with the MIG gun.
#2677
Took my 207 swapped WRX to a local Subaru show to showcase AwdArmy and run our vendor booth for the day.
https://www.facebook.com/groups/awdarmy/ for anyone interested ![]() ![]()
http://i840.photobucket.com/albums/z...93705d9zzz.png Last edited by Chuckls; 09-29-2015 at 10:07 PM. |
#2678
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
#2679
I actually DROVE my Yellow 5-Speed to work today...so it's wet and dirty.....
#2680
Went to a local auto cross, my first ever time, was second slowest of all cars DX
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#2681
So what was slower lol
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
#2682
Replace front oil seal, timing belt, valve cover gasket.
#2683
Ford tempo sedan, I only got to stay for the morning round too so ill wait for the results to be posted before I share numbers.
#2684
bishop, I suck at autocross, but my SVX is VERY FAST! When Jerry or Elezar drive it they are freeking fast! Like 10-14 seconds faster than me. But on an open road, with real death, as a posibility, I can be very very fast!
202 cid, 3580 #s, and we SMOKE Corvettes, Porshes, Mustangs. I am ok with that! If I had more money, for tires, etc. I would/will make it MUCH faster! Can you say 370hp and 2500#s? Full cage, great brakes, my own suspension. Yefknha!
#2685
Thread Tools | |
Display Modes | |
