Old 03-30-2006, 02:28 PM
Dr.Outback Dr.Outback is offline
Originally Posted by mbtoloczko
At one time I was running 17x7.5"/48 mm rims with 225/45-17 tires, and there was about 8-10 mm of clearance between the tire sidewall and the inside of the fenderlip when I had the rear of the car loaded down with the tire inside the fender. Based on that measurement, going to a 17x8" with a 40 mm offset will likely rub on the inside of the rear fender lip unless you roll the fender or run a very narrow tire.
When you say loaded down, do you mean 4 people, and luggage?
Old 03-30-2006, 02:30 PM
Originally Posted by The Hunter
I have 18" Axis Se7ens with 255-50-18" Pirelli P-Zero Systems on my SVX and have never had any promlems, but I wouldnt go any bigger then 18". My tires are thin enough now, I couldnt imagine hitting a pot hole rollin on a set of 20s. I noticed a big drop in exceleration but could care less cuse they look so Damn good. They fill the wheel wells perfectly I think. I got comments all the time that my car is lowered, but its not.
Do your tires clear the fender when loaded down with 4 people?
Old 03-30-2006, 03:53 PM
mbtoloczko's Avatar
sans SVX
I had a WRX 5-speed transmission in the back seat and a flywheel, clutch assembly, and other junk in the trunk. Probably was around 300 lbs worth of stuff between the trunk and the back seat. The rear fender lip was around an inch below the top of the tire, so it was perfect for looking at the clearance between the inside of the fenderlip and the side of the tire. Also, I was running about -1.3 deg of negative camber on the rear wheels at that time. If I were running less camber, there would have been even less clearance.
Mychailo
Visit my locker
Old 03-30-2006, 04:58 PM
The Hunter's Avatar
The Hunter The Hunter is offline
Answers to Questions
SolarSVX what you are looking to buy are Axxis Se7en MODs not the same wheel as me. Mine are the old style a lot less ricey looking without that big ugly lip. Just plain Old Axxis Se7ens are on my SVX.
Dr Outback, No one ever rides in the back of my SVX so I have no idea, nor do I "LOAD" my car with anything. I got a Ford Festiva beater for that.
and actualy for the last year my car has been in a corner of a heated garage awaiting a custom body kit and paint----- See Thread: "Bolt on Side Skirts" for more details.
When I was driving my car I baby it. Every signifigent little crack in the pavement or pot hole gets a full on stop. I dont drive fast around turns and beat it like It's a ralley car either. but under normal driving 55-75 on the highway and 25 through town I have had absolutly no rubbing at anytime.
Hope this helps.
Old 03-31-2006, 12:31 PM
Hope this helps.
Thanks, it does. I'll try to find a wheel with a little higher offset.
Old 03-31-2006, 01:37 PM
arondale
Rota's are replicates of Work Emotions CR Kai's... used on many SCCA racing-spec cars. Not that it makes them that much better... does give me bragging rights.
Work Emotion CR Kai
18x7.5
42mm offset
$2200 with Toyo Proxes4 ZR-rated direction tires.
Arondale
Atl, GA
Old 03-31-2006, 01:58 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
heres mine
Brand: Rota
Wheel: Action
Price: $600
Offset: +48 mm
Tire: 225/45/17 BFG KDW2
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 04-01-2006, 07:22 AM
andrew.anderson's Avatar
andrew.anderson andrew.anderson is offline
All these pictures do is make me want an SVX even more.
Old 04-06-2006, 08:29 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Originally Posted by rmjjensen
AZA Z2s
18"
225 40/18 (I think)
How much? Where did you get them? Do they make them in a 17"? What is the offset? Do they rub at all? Did you have to roll the fender? If they only come in 18" what size tire do I have to buy to keep them close to stock diameter?
dustin
-Dustin
Old 04-06-2006, 08:33 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
i just started a new thread on these
but It cant hurt to post a pic here too..
17x8s , not too heavy, good offset
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 04-06-2006, 09:01 PM
odepaj's Avatar
Killer of threads
Dayle, how much are you selling those for? I also might be placing a big order from you soon .
dustin
-Dustin
Old 04-07-2006, 10:14 AM
Originally Posted by odepaj
Earl, how much are you selling those for? I also might be placing a big order from you soon .
Earl has none but you may want to ask Dayle
Old 04-07-2006, 10:53 AM
mbtoloczko's Avatar
sans SVX
Wow. They actually fit. Offset does look fine. Interesting how the wheels have a much different appearance on an SVX than on a Mustang.
Mychailo
Visit my locker
Old 04-07-2006, 05:24 PM
odepaj's Avatar
Killer of threads
Dammit I always get them confused!!
dustin
-Dustin
Old 04-07-2006, 07:09 PM
just bookmark my site and add my email to your address book, and youll be fine
www.planetsvx.com
dayle@motorsportwarehouse.com
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
