Old 11-01-2003, 06:03 AM
6evil9
Shaking when breaking
Hi everyone
At the moment im experiencing problem: if i drive at speeds greater then 70 kmh and i start breaking, i get noticable shaking of the steering wheel.
Now i put new mags, which are heavier then facotry ones, and shaking is worse, but driving at highway speeds is ok, no shaking (as i guess i should ve get with bad balanced wheels)
Also i recently failed WOF due to my steering rack beein lose or something. (checked that today, and it seemed to be completely ok)
break pads are new ones
and i think all this shaking started after i hit curb at 60kmh... done around 10,000km since then. cheked thread of tyres, looks to be weared evenly.
So question is, shaking while breaking could be caused by what? most likely?
bad rotors? (how to check them)
bad wheel alignment? (how to check)
both sets of wheels bad balanced?(doubtly)
steering rack bent or lose? or something else?
waiting for replies.
Old 11-01-2003, 06:25 AM
6evil9
oh yup i also have my left outa cv joint clicking on full right turn. like its ok on the corners, but when i make u turn, it clicks (we drive on left side of the road, so turn right for u- turns)
dunno if its relative, but better say everything i know
cheers
Old 11-01-2003, 06:57 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
1st thing to check is that your lug nuts have been fitted correctly. Were they torqued on of gunned on?
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 11-01-2003, 07:11 AM
6evil9
lols sure i put proper wheel nuts (just changed mags today) and yes i ve tighten them
Old 11-01-2003, 07:15 AM
Andy's Avatar
......but were they torqued correctly. Overtightened nuts will warp your rotors and give the symptoms described
Andy
Old 11-01-2003, 07:17 AM
6evil9
hmmm well i got only usual nut key , how would i know whats the correct torque?
and 2 years ago, i have not tighten the lug nuts properly so almost lost a wheel, so now make sure lug nuts are tight...
Old 11-01-2003, 07:19 AM
6evil9
oh yup just woundering how "overtighten" lug nuts can affect rotors?????
or anything else...
Old 11-01-2003, 07:20 AM
Andy's Avatar
Sounds like your problem them. Loosen the nuts off and retighten diagonally to 75ft/lbs
Andy
Old 11-01-2003, 07:22 AM
6evil9
hmmm ok i mite get the torque key off my dad in the morning
r u sure its 75 the right torque
and some explanaition about overtighten lug nuts? pls
and have u experienced the same urself?
cheers
lols u r the fastest person who replies!
Old 11-01-2003, 07:28 AM
Andy's Avatar
Do a search and you will find it is a frequent problem. I had it myself and re-torqueing the nuts cured it.
The rotors are also secured by the lug nuts. If torqued incorrectly, the rotors cannot expand evenly when hot, hence the warping. If this doesn't cure it, you may be too late and new rotors will then be needed.
Andy
Old 11-01-2003, 07:31 AM
immortal_suby's Avatar
Thread Killah
I concur - I had a shaking problem in my wifes svx until I torqued the lugs equally. Problem gone.
Locker Link
2015 BRZ Limited 6MT
Old 11-01-2003, 07:33 AM
am i the only one who reads the owners manual from cover-to-cover a few times when i get a new car???
to anyone reading this - if you don't have an owners manual for your SVX, please do yourself a favor and get one!
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD!
2005 Forester XT Premium (Crystal Gray Metallic) SOLD!
2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+]
2015 Outlander Sport 2.4GT AWD (Mercury Gray)
2013 G37xS (Obsidian Black)
Old 11-01-2003, 07:45 AM
6evil9
Question
manual?
hehe i guess i ve read manual only for my cellphone and some for svx (trying to find cupholder in da car, and it was missing)
ok ok ill retight lug nuts.. first thing in the morning
just i dont wanna lose the nuts (sounds dodgy ) losing wheel on highway will cause the car go to wracking and me to hospital... if im lucky..... i know ill put that thread lock glue...
(did that for my personal plate... ended up drilling the bolts out )
what are rotors anyway?
Old 11-01-2003, 08:10 AM
6evil9
hey Andy, i forgot to mention, i ve changed lug nuts, so they are not that washer nuts anymore, they are conus (tapped?) ones.
what torque should i apply for them?
Old 11-01-2003, 06:21 PM
6evil9
ok I VE CHECKED THE LUG NUTS, THEY WERE AROUND 60-65 FT/LB SO WERE NOT OVERTIGHTEN.
i ve made them 70-75 ft/lb, done test: drove at speeds up to 125kmh, no shaking, but as long as i start to break at such speed (>80kmh) it feels like car wants to go left/right. like my front and left side breaks uneven: left stronger then right stronger... but maybe its illusion. stronger i press on the breaks, stronger is shaking, but holding the steering wheel tight, decreses the shaking of the car..
ok ideas now? (for whole info read first post)
