Radiator caps go bad?
You learn something new every day, as they say :/
Does it seem like my questions are easier than everyone else's or what? :p Not but 10 minutes after my last auto-x I noticed a coolant leak from a distance and found the area under the battery wet. Checked some things... nothing out of place. No biggy. I drove really hard, something probably got temporarily wacky. Today, I mobbed out to an inspection, noticed coolant leaking from about where the radiator is. Checked it out, could not find any leaks or even any wet spots aside from the oil pan, which was odd. Drove slowly and solidly afterwards, and made an apointment with Dan the man. We leave it running, he pops the cap off, stares at the drink for a sec, tells me to shut it off. Shows me the radiator cap. He says a good cap should take about 15-20 lbs of pressure to depress that spring. He was compressing it fully and with little effort from his thumb and guarantees getting a new cap would probably fix the problem. I never knew. Drove home slowly, no leak. Thoughts?
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
Yea I had to replace my cap a while back and it solved my radiator leaking problem..
until a hose eventually got loose and blew coolant everywhere... then I had to fix the hose and that solved the problem... until it started to crack by the neck.... then I changed the radiator and solved that problem.... ![]() I put new hoses and clamps on just in case ![]()
When I went to get a 16 psi cap about a year ago, I tested it for pressure before I installed it. It bled down at about 7-8 psi.
Regardless of the cap's condition, coolant forced past the cap seal under pressure should make its way to the coolant reservoir. Is your overflow reservoir absolutely full? If not, I think you'd do well to keep an eye out for a leak.
dcb |
Everything, given enough time, goes bad
![]() Dave |
Like my first wife.....
Don't get me started! ![]() ![]() ![]() ![]()
What about the second?
![]() and I'm considering a third??somebody smack me!
So the failed head gasket makes enough pressure to cause everything in the cooling system to fail one item at a time until you finally figure out what's happening. Of course, if the manufacturers designed their engines to run about ten degrees cooler, we wouldn't have to use pressurized cooling systems and none of these parts would ever fail, (except for the head gasket.) Kinda makes you wish you had an old Volkswagen. |
If wine sat around for 5,000 years I bet it would go bad ![]() Dave |
I don't think the rad cap is the problem.
My car did the same thing at autox last sunday. I know it's not my cap because it's new (came with radiator). I'm thinking the clamps on my lower rad hose are not tight enough.
I am also pretty confident my lower rad hose and cap are the only things that need to be replaced though. There's also the off chance the TB coolant bypass and T cooler bypass are making the thing run hotter, despite my temp needle reading about 40%. I've been wondering this since I installed the tranny cooler. If we remove enough components from the circulation of coolant, those parts will be cooler, but less heat will be escaping the actual circulation. Then I had a thought of running extra tube from the tb bypass into a small radiator or external cooler through the hood (: which I may do if I get a hood with a scoop :)
