the car looks good except for those wimpy headlights......car loks retarted with those lights on there.
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Anyone else notice the cupholders are missing? Man those suby designers really dont want anyone drinking in the car do they?
Woo Hoo! Now subaru will have 2 flops sitting on their lots. Hopefully they'll get back to making solid dependable awd cars and get away from this speed ricer concept they've adopted lately. Kill the stinking Impreza that consumer reports said way back when the platform was introducted in 93 wasn't all that impresive even though it was leaps ahead of the loyale.
http://www.subdriven.com/news/publis...icle_378.shtml Personally, I won't be surprised if the 'official' hp rating remains at 300...even though the actual rating will probably be in the 320-325 range. Subaru seems to be starting a trend of under-rating their engine output of late (e.g. '04-'05 Forester XT). -Chike
-Chike P.S. The more and more I look at the '06 Imprezas, the more I like Subaru's new corporate face.
I'll definitely test drive an '06 WRX this Fall. My wife likes them and it'll fall within the 26-27K price range she's given me. I'll also test drive an '05 Forester XT (still several new ones on dealer lots - hate the '06 redesign), an '05 Legacy 2.5GT and maybe even a pre-owned '04/'05 STI. However, I believe in supporting Subaru, so I'm 99% sure my next car will be purchased brand new. -Chike
new from Landshark Studios (a division of Jackass Industries)......new body kits for yu0r ugly '06 Impreza!
as i was messing around with these, i realized the headlights are almost as awkward as the grille. the foglights and lower rad opening don't seem to flow with anything, either. its a really sad design. Subaru is really dropping the ball.
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) Last edited by Landshark; 08-14-2005 at 02:22 PM. |
'06 WRX Specs...
2006 SUBARU IMPREZA® WRX®
WRX TR Sedan WRX Sedan WRX Sport Wagon WRX Limited Sedan WRX Limited Sport Wagon Specifications Body Styles 5-passenger sedan 5-passenger wagon (except WRX TR) Engine Horizontally opposed (“boxer”), turbocharged/intercooled Block Specially reinforced die-cast aluminum with integral cast iron cylinder liners, five main bearings, semi-closed deck cylinder block design Cylinders 4 Displacement 2,457 cc (150 cu. in.) Bore x Stroke 99.5 x 79 mm (3.92 x 3.11 in.) Heads/Valvetrain Aluminum alloy cylinder heads with double overhead belt-driven camshafts (DOHC), four valves per cylinder, Subaru AVCS (Active Valve Control System) variable valve timing and sodium-filled exhaust valves Compression ratio 8.4:1 Max. boost pressure 13.5 psi Horsepower 230 @ 5,600 rpm Torque 235 @ 3,600 rpm Fuel/Induction Sequential multi-port fuel injection (MFI) with multi-spray injectors and Tumble Generator Valves, Electronic Throttle Control (ETC) system, turbocharger, intercooler Ignition Direct with iridium-tipped sparkplugs Firing order 1-3-2-4 Emission control system Low Emission Vehicle (LEV) standard, 50-state certified CA LEV 1 / Fed Bin 10 Fuel requirement 91 octane minimum Alternator rating 12V, 110 Amps Drivetrain Symmetrical All-Wheel Drive Transmission types Standard: 5-speed manual transmission Optional: 4-speed electronic automatic with lockup torque converter (WRX Limited models only) Man. trans. All Wheel Drive Viscous-coupling locking center differential Auto trans. All Wheel Drive Variable Torque Distribution (VTD) using planetary center differential and electronically managed continuously variable transfer clutch Gear ratios 5-speed manual 4-speed electronic automatic 1 3.545 2.785 2 1.947 1.545 3 1.366 1.000 4 0.972 0.694 5 0.738 -- R 3.333 2.272 Final drive 3.70 with viscous limited-slip rear differential 3.90 with viscous limited-slip rear differential Chassis Unitized body construction with Ring-Frame Reinforced structure, hydroformed front subframe and tailored blank-welded side sills and B-pillars Suspension 4-wheel independent, sport-tuned (sedans with wider front track) Front MacPherson-type struts with steel lower L-arms, aluminum transverse links, liquid filled L-arm rear bushings, coil springs, stabilizer bar and negative-scrub geometry Rear MacPherson-type struts with coil springs, trailing arms, twin aluminum parallel links and stabilizer bar and negative-scrub geometry Brakes Power assisted 4-wheel disc with 4-channel, 4-sensor anti-lock brake system (ABS) and Electronic Brake-Force Distribution (EBD) 2006 Subaru Impreza WRX Specifications / 2 Front disc size 11.5 in. x 0.94 in., ventilated with 4-piston fixed-position calipers Rear disc size 11.3 in. x 0.71 in., ventilated with 2-piston fixed-position calipers Steering Rack-and-pinion with engine-speed controlled variable power assist and load-sensing valve Ratio 15.0:1 Turns, lock-to-lock 2.7 Turning circle 35.4 ft. curb to curb Wheels 17 x 7.0JJ aluminum alloy Tires 215/45 R17 91W Bridgestone RE92 all-season Exterior Dimensions Coefficient of drag (Cd) Sedan: 0.33 Sport Wagon: 0.37 Wheelbase 99.4 in. Length 175.8 in. Height Sedans: 56.7 in. Sport Wagons: 57.7 (58.5 inc. roof rails) Width Sedans: 68.5 in. Sport Wagons: 66.7 Track (f/r) Sedans: 58.5 in. / 58.3 in. Sport Wagons: 57.7 / 57.3 Ground clearance 6.1 in. Curb weight (lbs.) 5-speed manual 4-speed automatic WRX TR Sedan NA NA WRX Sedan 3,192 NA WRX Sport Wagon 3,252 NA WRX Limited Sedan 3,239 3,296 WRX Limited Sport Wagon 3,294 3,347 Interior Dimensions Headroom (f/r) Sedans (ex. Limited) : 38.6 in./36.7 in. Limited Sedan (moonroof): 36.3 in./36.6 in. Sport Wagon: 39.7 in./37.3 in. Limited Sport Wagon (moonroof): 36.3/in./36.6 in. Legroom (f/r) Sedan: 42.9 in./33.0 in. Sport Wagon: 42.9 in./33.7 in. Hip room (f/r) Sedan: 53.3 in./51.9 in. Sport Wagon: 53.3 in./51.7 in. Shoulder room (f/r) 52.7 in./52.9 in. Trunk volume, sedan 11.0 cu. ft. Cargo volume, Sport Wagon EPA rear seat up: 18.0 cu. ft. SAE rear seat down: Pending EPA interior volume Sedan – 87.6 cu. ft. Sport Wagon – 90.4 cu. ft. Capacities Fuel 15.9 gal. Engine oil capacity 5.0 qt. w/ filter Coolant capacity 8.1 qt. (8.0 qt. with automatic) Towing capacity 2,000 lbs. (Class 1), 200-lb. tongue weight Fuel Efficiency 5-speed manual 4-speed automatic EPA city mpg 20 21 EPA highway mpg 26 26 http://www.subdriven.com/news/publis...icle_390.shtml -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 08-14-2005 at 05:24 PM. |
Hotness.
I don't mind the front end as much as I thought I was going to. And i have to say, I think it definitely gives the company a "common face" while a lot may not agree with it, at least you'll be able to instantly recognize a subaru on the road. Think about how you can always tell BMW's, Pontiacs, Mercedes, and Porsches immediately just by the nose. I think it might help subaru more than we realize.
Plus, i GUARANTEE the 2.5t to be going faster than the 4g63 by the end of 06 Displacement helps.... especially when putting down streetable power.
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
You know I just noticed the radio antenna, or lack of one. I would Absolutely love to get my radio antenna shaved off. I hate how it looks and how it wobbles going down the freeway. But the reception absolutely sucks when its not extended.
The more I look at the front end, the more it looks like a legacy rather than an impreza. I just looked up what the TR was, cause i hadn't heard about it. Apparently its "Tuner Ready" and sells cheaper. Sounds like every teenager and their little brother will be buying those up. All I can say is I can't wait for the 2008 Revision, hopefully they wont let quite so many subaru enthusiasts down next time. Last edited by Tim-H; 08-14-2005 at 04:00 PM. |
#28
#29
While the Baja turbo is extremely fast, b/c it's built on the legacy platform (unlike the Forester XT that's built on the impreza) it weighs a stout 3,400-3,500lbs. I really want a light-weight car that I can use both at the dragstrip and autox events. The Legacy 2.5GT and WRX are therefore my front runners. -Chike
#30
didn't you know that WRX's are for t00ls?
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
