shifts hard....
when i'm accelerating and my car shifts from 1st to 2nd gear it kinda jerks when it shifts.....it also takes a while, the RPM's don't raise but it just revs at the same point for like a second and then shifts hard. Does anyone have an idea or experienced tha same problem with there SVX.
Re: shifts hard....
Re: Re: shifts hard....
I'll chime in on the "resistor" statement. Mine shifts really hard from 1 - 2 when the resistor is unplugged. (Only reason I plugged it back in) Randy (Has plugged resistor, nose, bathtub) ii |
My 1-2 seems to shift quicker / harder than 2-3 and 3-4, but it's really quick. yeah...
I have the same problem, where do I find the resistor?
Andy |
Behind/Next to, depending on your perspective. Stand at the front of the car with the hood open, looking at the engine. Look at the battery. Look to the right of the battery. Bolted to the inside of the engine bay is the resistor. There are little clips that need to be pressed in to unplug it. It's easier to do if you remove the battery and unbolt the resistor, but thats kind of a hassle... try just using a needle nose pliers to press the two clips in, then with your other hand push against the pliers to try and remove the plug. That worked for me..
Just for the record, my 1-2 has always been abrupt (both when it had the Legacy tranny and after the many incarnations of my current genuine SVX tranny). I think that's somewhat normal (for 92's anyway. Don't know about other models).
Now, if your 2-3 and 3-4 are "slamming" then, I'd suspect the resistor or duty solenoid A. The resistor would be the cheapest fix. Check the resistance. I don't know what it's supposed to be, off the top of my head. Somebody? Anybody? I know one of you guys has to know. ![]()
Resistor
Resistor should be twelve ohms when measured out of circuit. I would not worry about + or - one ohm.
My 92 shifts as smooth as. It is hard to detect shift points during normal driving but all are quite tight.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 04-22-2002 at 10:25 PM. |
my first thought was that it......
has to be ther tranny mount. my car did that for a while but sporadically. took it in and it was the tranny mount. like a loud clunking sound. i would check that first.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
