Mazda B3000 Question
My roomate just had his 1999 Mazda B3000 checked out at a local Big-O tires place. His auto hublocker had fallen out of the wheel for some reason. We took off the wheel, replaced the hub locker, and reassembled, and all was well. However, jsut to be safe, he took it to have it checked out. They said it was fine, but that he needed alot of OTHER stuff done (typical). Here is the run down:
Camber Kit 2x$25+$50 in labor=$150 Upper control arm assembly w/ball joint=2x$200+$69 in labor=$538 Lower ball joints=2x$64 +99 in labor= $326 Alignment, Thrust= $49.99 Shop fees= $53.20 Tax= $38.73 Total= $1,155.92 Now, he doesnt feel anything wrong while driving, and the auto hublocker was fine. So how can someone justify $1200 in work for something that isnt really broken? Well since I am always working on my SVX, I figure I might try to do some of this work myself, if it isnt too hard. Anyone know anything baout this stuff? I know ball joints in an SVX are easy, but how about in this truck? |
Camber kit....Is his alignment off? (are the tires waearing poorly inside outside {out of round he doesn't feel anything so no go})
Upper and lower ball joints.....are the falling apart? (grab tire and rock back and forth too much movement in those suspension bits could mean that they are going bad.... Alignment should be included with the new camber bolts. My vote Big-O should not be visited again if everything is still good.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. ![]() 92 SVX LS-L Perly ~186k R.I.P. ![]() 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I'm no professional, and I've never worked on a Mazda, but it seems to me that they are charging separate redundant labor, when most of the work is common between all the components to be changed????? As it relates to a Subaru that would be like charging $20 (P) +$50 (L) for Cam Seals and at the same time charging $75 (P) + $50 (L) for the timing belt...
One thing I like about my mechanic: He has never, ever tried to sell me anything.
An $1000+ estimate for work one didn't know was needed begs a second opinion. At the very least, get a competitor's quote. dcb |
Get that ford ranger to a second and possibly third opinion
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya ![]() Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere ![]() I decided to quit drinking, but I didn't like it so I quit not drinking. |
If its a 4x4 with the vacuum hubs you can get a manual hub conversion for under $200 as these are the same as a Ford Ranger. Tech info here http://www.therangerstation.com/tech...onversion.html and http://www.therangerstation.com/tech...to_hubswap.htm . Hope this helps
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT ![]() |
