When my car is in drive [D] and I have my foot on the brake, my car kinda hiccups and shakes for a split second and then returns to normal and then at random intervals do it again.
If I pull the E brake and put the car in neutral at a red light it seems not to do it as much or at all. My car idles at about .5 and when the "hiccup" occours the rpm's really dont move. The car responds great when the light turns green ![]() Could a clogged EGR line cause this? Im thinking its air or fuel. I hope its not timing ![]() |
Could it be a binding AWD clutch finally letting go?
A coil or a plug on the way out?
Ok, so the plugs on the car dont have a normal spark plug boot. Its like a flat piece of plastic covering the plug. Are they hard to change?
Does each spark plug have its own coil? ![]() |
