#691
#692
A very low duty cycle can in fact result in a virtual fully open or closed valve depending on configuration, without the signal appearing as absolute D.C. The solenoid armature and valve components have weight, and friction also exists, both affecting electrical efficiency. Therefore a time constant is involved in respect of the onset of reciprocal movement.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#693
Just confirmed that with the FWD fuse in place, Solenoid C reports 95%.
#695
#696
Been thinking about the way the B solenoid drops to 55% duty cycle, instead of either on or off. I think that the lock-up clutch is applied all the time and is not released for gear changes. It just drops the pressure applied to the clutch, so that if there is any sudden change in load during the gear change, the clutch will slip to prevent any shock being felt. Harvey.
#697
Nomake,
Solenoid valve B is controlled by the TCU such that when lock up is called for, the valve is initially only half engaged, to be gradually increased so as to achieve a smooth take up.
#698
I figured that, Trevor. However, what I didn't understand is why cruising around, it stays at half-engaged instead of going to fully-disengaged.
#699
Solenoid valve “B” is normally closed and energised to open. When at a duty ratio of 95% the valve is opened to drain and no lock up duty pressure is available. As a result the lock up control valve, through a pressure differential arrangement, causes lock up. This set up is possibly the reverse of what you may have assumed, but the end result is as you will have expected. The pressure differential arrangement assists with smooth partial engagement when SV “B” is part open, say 50%. You have advised, --- ”If the transmission is in "Normal" mode when you disengage the cruise control, it drops to 55%, but does not go down to 5%. So when driving around without Power Mode, the torque converter appears to be in a semi-locked state." SV “B” is under direct control from the TCU and vehicle speed, engine speed and the selector signal are all involved in the control of lock up. Therefore a signal could be present which you have not taken into account and further observation may provide a clue. Unfortunately there is no evidence within the available data which otherwise explains your findings.
#700
Updated version of the tcuscan software. Some extra features and hopefully a few bugs fixed.
It's a bit slow because of all the values it's reading. I think that is why the original select monitor only displays one value at a time. EDIT: Updated again with some more features and bug fixes. It still looks like a GCSE CompSci project from the 1980's. ![]()
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 04-29-2008 at 05:09 PM. |
#701
Yesterday was an epic day for this project. I made two major steps forward.
Firstly, I have successfully reprogrammed a TCU and it's quite easy to do: You have to remove the existing ROM chip, then solder a socket onto the board in the space provided, then program the new eprom and put it in the socket. A Picture speaks 1000 words (but takes up more disk space): ![]() To remove the ROM chip, heat each of it's legs one at a time with the soldering iron and slide a knife blade underneath to separate it from the board. Finish one side first then the other. ![]() That choking noise you can hear is Joe having a fit because he's just realised that it is HIS TCU that I am experimenting on, with no guarantee that it will ever work again. ![]() After removing the chip it is necessary to clean up any remnant solder around where the chip used to be to avoid shorting anything. ![]() The next step is to clean out the holes where you are going to install the socket. This is a time-consuming process which involves repeatedly burning oneself with the soldering iron. The best method I found was to hold the board vertically, put the soldering iron on one side of each hole and the solder sucker (spring-loaded syringe) on the other side. When the solder melts you fire the solder sucker and it sucks the liquid solder out of the hole. ![]()
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 05-02-2008 at 02:17 PM. |
#702
Having done that it takes just a moment or two to solder the socket in place
![]() Then it's time to program the new chip. I am using an SST 27SF512 eeprom chip supplied by Calum and a cheap chinese Top2004 programmer from ebay. The data I am writing to it is a UK TCU image that I have modified so the economy switch will engage power mode instead. After writing the chip I read it back and verified it against the image file to ensure it had been written successfully. ![]() Here is the modified TCU with the eeprom installed. ![]() Then I took it out and plugged it into the car to check that it worked. And it did!!!! I used the select monitor adapter to connect to the TCU and download the part of the program that I had altered, and it matched perfectly. The very fact I was able to connect proves that the device is working. So hardware side of modifying the TCU is now possible. ![]() However, there seems to be a bug in my software changes. The power mode is stuck on permanently. ![]() Phil. ![]()
#703
Very cool Phil, The first time I opened a TCU case, I knew it would be as simple as loading a socket and writing the new eprom... Just don't have the level of commitment or expertise you do... Good work!!
Tom |
#704
Secondly, I have managed to modify the ECU. Remember the printed circuit boards I had made up?
![]() I was having trouble finding the components to go on them, but Calum was able to source them for me. Thanks again Calum. The first step was to fit a socket onto the motherboard of my ECU. Most SVXes already have a socket, but my JDM ones don't. ![]() The procedure is exactly the same as described in the TCU mod above. Clean out the holes and solder in the socket. I also removed the tan resistor that activates external memory. ![]() Then I started to build one of the boards ![]() First I soldered the components to the top side ![]() Then I fitted the pin lines on the underside that plug into the socket on the ECU. ![]() Then it's just a case of writing the eeproms and plugging it in. ![]() I went out to the car, plugged it in and it works perfectly. As before I used the select monitor adapter to download part of the modified program and compare to my original file. How much more horsepower do I have? None. Yet. My black 92 is now running the JDM 94 program with the 180km/h speed limiter code removed. I'll reprogram the eeproms as and when we come up with some useful mods. Phil. ![]()
#705
Phil,
You are most certainly one who deserves an STI gong. ![]() Trevor.
