Old 06-20-2008, 07:41 PM
aust92pearl aust92pearl is offline
a few weird lil issues
sometimes pwr light will work fine on start up and work while driving and other times on start up it will flash several times and not work for that trip also sometimes while rolling at 50 60 kp/h it will erratically and randomly change between 3rd and 2nd any ideas of wat the hells hanin to my lil baby lol
Old 06-20-2008, 08:06 PM
kwren's Avatar
kwren kwren is offline
Re: a few weird lil issues
It may not even matter
Old 06-22-2008, 04:21 PM
okok and just wats that suposed to mean.i was just askin a question no need to be an ass about it .its not as if i asked you that question personally anyways
Old 06-22-2008, 04:52 PM
redlightningsvx's Avatar
Collision Refinishing Tech
how many times does the power light flash?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-22-2008, 05:02 PM
The flashing power light indicates there is a transmission fault code stored... Go to svx-iw.com and pull up the how to check TCU codes in the svxipedia section. This may or may not be related to the awkward shifting you are experiencing but it may be a good place to start. My money is on the TPS sensor being faulty or out of adjustment.. Let us know what the code tells you
Old 06-22-2008, 06:39 PM
kwren's Avatar
Gee, sounds like someone got up on the wrong side of the bed? My power light flashes occasionaly but the car runs great to the tune of at least 40,000 miles a year. I seriously just suggested it may not matter. Was a suggestion and didn't realize you had some kind of an arrangement on this form that you just submit a Thread, and everyone just hangs out waiting for you to call their name before they can respond?
Can't be just an austrailian thing. Harvey is certainly not that way
If I should try to give some input in the future on one of your Threads, please disregard it. It might happen unintentionally, because I am sure I won't remember your name.
bye
Old 06-25-2008, 07:28 AM
yeah sorry kwren had a really bad day that day um lookin up codes in the morning i suspect alot more than one problem
Old 06-25-2008, 09:43 AM
kwren's Avatar
Understood!
Hope all works out great for you...
Take care,
Keith
Old 06-25-2008, 05:39 PM
ok did the diagnosis thing and it came up 3 long and 1 short which says its the throttle sensor lol um im not sure if there was more it just repeated 31
Old 06-25-2008, 06:32 PM
oab_au oab_au is offline
Well an electrical noisy Throttle position sensor will cause the down shifting that you have. I would get a new one as a second hand one may be just as bad.
One Arm Bloke.
Tell it like it is!
Old 06-25-2008, 09:04 PM
Trevor's Avatar
Trevor Trevor is offline
There is information within the How TOO section regarding testing and cleaning the TPS. You are involved with a quite expensive item and this would be a sensible initial approach.
You report an intermittent problem which could mean a patch of dirt on the resistive plastic TPS elements. However this could also mean a very short term missed contact, which will be hard to detect with a meter which has slow registration. A meter with a bar graph, or an oscilloscope will provide an absolute test.
Trevor, New Zealand.
Old 06-25-2008, 09:11 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
I'd start off with the basics and adjust the TPS to .5 volts at idle. There is a write up in the "How To" documents. I had a similiar problem that was corrected by adjusting the TPS. If that doesn't work then try further testing the sweep of it and cleaning. If that doesn't work, then I guess it's time to get another.
But then I'm, a cheap & lazy bastard... I always try the free fixes first.
