Alternator male plug remove
Help!
I need a detailed explanation on removing the male plug on the left side of the alternator next to the PS tank. I have pryed and pushed and pulled on the clip. plug won't budge. Since it's plastic I don't want to break it. TIA ![]()
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! ![]() |
Re: Alternator male plug remove
Thank you! I'm not used to seeing them with a clip that actually retains the plug... I would be interested in a replacement to splice in
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
As long as the battery is disconnected use a flat blade screw driver to pry the clip in while you use a needle nose plier to pull on the plug to get it out
Tom |
I got it out, broke the top arm to the clip. Had to solder a chewed thru wire, all is good. Dave ![]()
