Re: Baseline Dyno 7/16/08
I imagine you would have broken 200whp if you had a 5 speed instead of a 6 speed, correct?
Tim, that may be true but I cannot say yes without being skeptical. Tom |
-Bill
They are between 32-34" with more ground clearance in mind on this set it would have been near impossible to make them any closer in length.
BTW here's the sheet tom |
Nice numbers! I am interested in seeing where this one goes.
using 27% loss in the driveline rough math puts it about 260 at the crank.
Tom |
YT,
Can you get SAE corrected plots? Most of the data in my dyno database have this correction. What gear did you do all of the pulls in? Thanks. -Bill
Tom |
Jack's car runs 32" long 1.75" primaries, and while I honestly thought they were too big initially (we were eventually planning forced induction when I built them), they ended up working quite nicely with our modified high rpm N/A setup. |
Tom |
http://www.rs25.com/forums/showthrea...2dyno+chart%22 |
Peak power stands for little in my book. It's all about the area under the curve.
#28
Tom |
#29
Nice numbers Tom!
Better to compare other cars that have dyno'd on the same dyno. Area under the curve is all good but just remember there are other variables to consider as well. Sure an RS making the same peak with less hp/torque under the curve can appear to be slower all around but if it is lighter (depending on how much lighter), it could blow away an SVX with a better 'area under the curve'. Or two SVX's making the same hp/torque and the same weight but one has lighter weight wheels and junk-inside-the-trunk vs one with heavier wheels and no junk inside. And the variables go on...... Looking forward to seeing how things turn out Tom. A friendly race or two at the track would be nice. ***Heading back into the shadows***
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
#30
not charts but here are some numbers from others running the same day...
Tom |
