Forged internals
I was wondering if anyone knew where I could sorce some forged pistons and rods for the EG33. I seem to remember ECUtune selling them some time ago but now all I see them selling is full long blocks and I sure don't have the money for all that.
Re: Forged internals
Searched a little more, found some info but didn't want to dig through 13 pages of trials so I'll ask this lol
Can I use EJ22 turbo pistons and rods? What would the compression be? I see the pistons are the same, didn't see if the rods are the same or not... I'm expecting bad news as its be like 4 years since that thread started and I don't hear about anyone doing it. |
They are not the same....
Tom |
In that same old thread I saw you say 8.5:1 wasn't ideal for our motors... What do you recommend for turbo applications?
8.5 would be ideal in the EG33 w/ boost. Just not 2.2l pistons
Tomm |
I thought 2.2T pistons fit for a boost application?
The 2.2t pistons would give us a compression ratio of 7.5:1 or lower
![]() Way to low for any kind of usable power ![]() The difference is in the combustion chambers. Eagle rods and CP pistons are your best bet right now as they can be had for fairly cheap. ACL makes the proper sized bearings for our cars, they are tri-metal bearings and are looked down upon by some people ![]() Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
Whats the price for the CP pistons?
Also, where can I source a gasket rebuild kit? I got the price of a Cometic head gasket already. I'm trying to get a price list together. |
An even less expensive route, if you can source them, is using STi rods.
-Bill
Which year? Are they the same as WRX rods?
I have another question about building up the motor if its okay to ask here.
I've been looking into cams lately, I've been wanting to keep the stock springs and valves cause it sounds like a lot of work to convert them over to WRX parts... Well a good friend of mine recently had his built STi blow up the second time and hes considering going back to stock, and I told him I'd take two of his rods and the heads if he wanted to get rid of them. What all is involved in going swapping over the head parts? I'm severally intimiated by this as I have no experience with head work.. |
beyond the fact that you will be 2 cylinders shy of the parts that you need... Im not sure....
The impreza valves and springs are used when converting to solid lifters instead of hydraulic lash adjusters. You have to grind your cams on a base circle that roughly matches your valves and lifters and then get the correct shims to fine tune the lash adjustment.
