Re: adjusting brake band - dealer told me
After years of 200° temps. jack jabbit starts, sitting in traffic, and the occasional tire spin,(snow or sand) tiny friction particles have been let loose in the system as the in transmission screen is not a filter, just a screen. The hot mix of burnt friction material, dirty oil, metal shavings get lodged into cracks, like dust in the corners that never get swept. Now someone hooks up a high pressure flush of some harsh cleaner followed by fresh fluid, and washes out all of the crap. Suddenly the old dried out seals, no longer flexable, have bigger holes to seal.
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link |
Level 10 in NJ makes a transmission too
1992 Liquid Silver/Black LSL LeveL10 Stage 3 Trans and associated stuff |
I forgot about them.
Just trust him FLUSHING IS BAD!
I, too worked at a dealership, (bmw, mazda, isuzu) and they stopped doing flushes on cars with high miles because the majority of the cars they flushed came back not too long after needing a new transmission. And a more recent example: My girls dad just replaced the transmission on his girlfriends 05 ranger because her transmission was shuddering a little going into O/D and she took it to the dealer they flushed it and it got noticeably worse. |
Not trying to argue just trying to understand. |
10 characters.
drain and fill is fine, just don't power flush, that is what stirs the crud up.
I suppose the lines at the radiator should come off and let it drain out of the radiator.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
I do use compressed air to blow through the trans cooler in the radiator both ways to make sure it's clear, once both cooler lines are disconnected.
Shouldn't one bypass the trans cooler in the radiator in favor of an external trans cooler. I thought it was agreed that they become clogged due to the mesh inside pre '92. I did this years ago and have had no problems and better temps.
![]() The current thinking is to bypass the stock in rad trans cooler with a medium sized one to allow more flow in the trans. The trick is to allow full pressure, and still mantain a >150°f, and <200°f transmission pressure.
