Rear bearing
Are there two separate bearings for the rear wheels? I'm looking for the parts online and I see two that are completely different looking.
Re: Rear bearing
Both sides are the same. The bearing comes as one "part", but can be split into 5 pieces (outer race, two roller sets, and two inner races). The bearing and both seals (P/N 28015AA070 and 28015AA080) should be changed together.
The bearing is #21, the seals are #23 and 24.
Re: Rear bearing
Thank a bunch!
Re: Rear bearing
Also, have you ever changed this? Is it do-able without special tools? I've done it on other cars without much problem, but this assy looks a little more detailed than I'm used to.
Re: Rear bearing
I'm attaching the How-To I used for my bearings. It's an excellent guide and I'd like to give credit to whoever wrote it, but I can't remember.
I've got to run but post up any questions you have and I or someone else will help you out.
