stator shaft removal
i'm trying to remove the stator shaft off an svx transmission i have laying around for a member on the forum.
i was wondering what the easiest way to remove it, is there a c-clip or do i have to take the front diff off?
Re: stator shaft removal
can anyone help shed some light on this so i can get the part for a member so he can get his car running?
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... Last edited by Gamesy; 01-10-2011 at 11:14 AM. |
i got the front diff off and am working on taking the pump off are there any hidden nuts or bolts that keep it on? i took off whatever i could find but its still stuck on
how to take it off
take off front diff take off rear diff remove nut off power transfer shaft that runs from the back to the front ( the nut is NOT reverse threaded) once nut is off you can pull out the shaft and the pump will come off and there are just a few 12mm bolts that hold it in plate
