Old 03-13-2012, 08:59 PM
THE NEW GUY THE NEW GUY is offline
Re: Transmission Failure on the way home tonight....
manual option works only on 3rd and 2nd gear. it forces tranny to start in 2nd speed without passing trought 1st speed to avoid slipping in certain circumstances.
Shifting the lever on 3rd gear with the Manual light on, the first lowering rpm you see on the tach is cause of the tc lock in 2nd speed. then, the second lowering rpm is when tranny changes to 3rd speed. If rpm goes too high in 3rd speed, tcu will engage 4th speed to protect the engine. same in 2nd and 1st gear.
Old 03-13-2012, 10:05 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Ok so the locking of the TC (because it is in manual and locks at a lower speed?) is what allows the smooth shifting from 2nd to 3rd whereas in regular drive mode the TC doesn't engage until a much faster speed is reached so the flaring from 1st to 2nd and 2nd to 3rd is due to TC not being locked? If that's the case, would this not be related to an out of whack brake band adjustment? or is it just because something is actually broken?
*edit* Never mind that... I'll just accept that something is definitely worn/broken and unfortunately it's inevitable the tranny needs replaced. Thanks for all the responses/feedback guys!
1994 subaru svx le 112k
Old 03-14-2012, 12:58 PM
Austin Austin is offline
You don't need to check it in "D".
You need to cycle it through all gear positions and then back to Park. This is the same procedure for any automatic transmission.
Something I found out the hard way last week. Now I'm looking at either an expensive tranny transplant or selling my 96LSi.
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - soon going to a new home)
'89 XT6 5 speed (Gone but not forgotten)
Old 03-14-2012, 01:24 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
You can do it on the cheap side if your source all your parts and get a good deal on labor!
I think I spent ~500-600 on the tranny/rear diff. then 700 on labor.
