OBDII Mt conversion???
I have heard that OBDII cars have issues with being converted to a standard shift. Has any one else heard of this? And why is it?? I would really like to try it myself and I would be willing to cut a pretty good deal on the first person who wants it done... More or less it would be feeding my curiosity
Tom |
But this is my daily driver and I need to get around. I don't know why it couldn't be made to work. >
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I have heard that the CEL will pick up the lack of a TCU... But I am not sure anyone confirmed this... If so, I would like to come up with a fix for the problem. Just throwing around the idea because I do not think there is a single OBDII mt SVX out there right now
Tom |
Tom,
I think the biggest stumbling block has been the lack of an ECU pinout diagram for an OBDII SVX. That stopped me from switching to a full stand-alone on my former '96. Get that, and I'm sure the swap can be done.
Hmmmm... I wonder what prompted this interest... lol
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
i was really sparked by her and curiosity is gonna kill me... Just like that twin idea I have burning a hole in my head
Tom |
Re: OBDII Mt conversion???
Sorry to drag up an old thread, but has anyone successfully converted an OBDII car to a manual transmission?
Sure, but not without a permanent CEL
Really?
All the ones that I have done have been OBD1s.
Did a 97. 96 will as well due to the com link between the TCU and ECU.
One thing on my to do list is monitor that pin and see what the signal looks like. It is also the only thing keeping me from trying and OBD1 TCU in my 1996 to get the upgrades.
What? You mean " The 1997 will as well , due to the com link between the TCU and the ECU. I had to read that 3 times
Its a data line between tcu and ecu reporting the status of the tcu.... you will not be able to reproduce it
Tom |
You underestimate me.
Good luck replicating everything the TCU would see and have it report back to the ECU. It's not a simple range of voltage but complete communication back and forth.
