I summon the help of the SVX guru's! faster steering rack
Ok so i read that our cars came with 3 possible steering ratios. Mine is a 96 LSi so i have the second worst available ratio. I read that the 4 wheel steer cars came with a much better steering ratio and i want it!! My questions are as follows:
Did subaru ever make a left hand drive 4ws svx? If they did it makes my life alot easier! If they only came in right hand drive jdm/uk cars, would it be possible to swap the guts from the right hand drive 4ws rack into a left hand drive rack? Does anyone happen to know the part number for the 4ws rack? I really want to make this happen! Ive done pretty much everything else i can to make the car handle its best but the damn steering is way too slow for how i want to drive it. To everyone to even attempts to help me with this matter I thank you in advance !!!!! ![]() |
Re: I summon the help of the SVX guru's! faster steering rack
I think you are going to be out of luck as 4WS was only offered in Japan/Australia/New Zealand & UK eg NOT LHD
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Ok so i can scratch that option off the list. Hopefully i can find a way to first of all locate a 4ws rhd rack and then manage to swap the guts to a lgd one.. thanks for the info!
Maybe Shane Hobson (shanehobson) - here in NZ has one, he has lots of spares & also owns a 4WS model.
Awesome! How might I go about getting in touch with Shane Hobson?
either PM him or leave a message in the "down under" area
