#1336
Re: ECUTune Stage III twin screw supercharger sign up
Oh and I forgot to say Thank you for at least trying on this. I still say it has a lot of potential, but potential probably isn't everything (ie. money). But again thanks.
#1337
Dang... I swear I have seen supercharged SVXi out there. Are they from a different source? One-off creations? I want a bit more power in my SVX, the 5 speed is amazing, but a little more zip would sure be nice. Anyone selling one of these old kits by chance? :-)
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
#1338
Time to learn how to fabricate. I have one of the kits and I have had to rework most of it to get it setup well. Looking back on it, a large single turbo on my built motor would have gotten me a lot more for the money with way fewer headaches.
#1339
Can you expand on this thought please?
#1340
I'm limited to around 11psi while over revving the supercharger before redline. On a high compression motor this may be fine, but I have a forged lower compression motor. I could get much more out of it with a more efficient turbo pushing higher boost levels. To get any more from my current setup I would need to either add a turbo, or go to a larger supercharger with a larger pulley so I don't over rev it.
#1341
I'm a few months late to the show here. I had the first customer car with the kit. I was military at the time. It was originally a 1994 Red FWD L model. The trans went out during tuning the car. I had Tom drop in a 6-speed manual. It was running 9lbs boost. I transferred out to San Diego and sold the car to someone from northern California, along with parts to start a built engine (CP pistons and Eagle Rods). I want to say I sold it some time in late 2010 or early 2011. I couldn't get it tagged and had moved on into a new Camaro SS.
#1342
https://www.shopnonstoptuning.com/st...STpulleys.html
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
#1343
I'm rebuilding the shadow machine giving it a stroked 3.7 have not ever drove bought it torn apart was thinking of adding 2 sts turbos i have looks like i need to look at the supercharger on it to see if it can handle the added rpm's
#1345
Model Displacement Max Continous RPM Max Peak RPM Max CFM Max M^3/HR Max PSI Peak VE Peak AE SC Blueprint (PDF) W100AX 1.6 Liter/rev 18,000 20,000 1120 1902 30 99 81 100AX https://whipplesuperchargers.com/ind...iew&page_id=15
#1346
I plugged in what I "think" our ratios are from memory and it looks like you could get up to an 8" crank pulley before you're getting close to the maximum rev limit of what our superchargers can handle.
https://www.blocklayer.com/pulley-belteng.aspx
#1347
Also this isn't the w100ax it is a 1600ax which has a listed max RPM of 13,000 and the graph is tested to a max of 15,000 RPM. |
#1348
Doh, you're right. I was looking at the wrong model on the chart. I didnt realize the max rpm for the 1600AX was so low. I wonder if the 100 has the same dimensions as the 1600AX. Maybe it could be swapped out with the newer model?
#1349
Mike DO you have this set up?
No, he only made 7 kits and they are scattered across the world. I have one in Texas, Jason has one in Massachusetts and i'm not quite sure where the rest are. I think one made its way to Australia, but i could be wrong.
Ray
