Old 11-13-2021, 05:48 AM
Re: Lsvx-t
Originally Posted by Stevebsy View Post
I don't have the stuff yet, so I can't send it anywhere..
Besides..this is my crazy project :P Not sure I want to spend ~$12k for batteries, motor, controllers, charger, etc.. on my $4k SVX though...
It does kinda look like it might work without too much surgery.
This video series is a big inspiration. It's a Porsche Boxster conversion
https://youtu.be/ZyASP8h9izo
The $ is never going to make sense. Hell I have a lot more putting this rig together and its a dinosaur comparatively. It all depends on what you want out of it. Unless you really go all in, it's not going to be a daily driver. You will have it more as an obscurity. I mean the rest of the supporting parts for the vehicle are non-existent so it will be a never ending jam session of fabrication and "making it work" that I am running into as well. Even after spending a year and a half putting this together I have still got this for my punch list
-Bulkhead for rear/trunk
- Parking brake handle mounting and cable fab
- Overflow tank mounting and routing
-Fuel vent filter install
- Indicator lights and wiring
- Alignment
- Hood (figure something out already)
- Fender flares
- Body work
- Dyno tuning
- Tires
- Enclosed trailer for storage and transport
- Defrost kit
- A/C system design and install
This list will never end but that's just things actively on my mind
Old 11-15-2021, 03:31 PM
Re: Lsvx-t
So I'm always shopping deals and I just pulled the trigger on a used ls3 intake for the car. My hopes for this are to gain back some much needed hood clearance. Now I did already cut my hood up but I may be able to salvage it. Worst case scenario I can use a smaller bump which will help the eye appeal. More updates when I can find time to get it fitted amongst other pieces.
In the meantime rest easy that this is an absolute monster and I am not totally sure I will ever have traction WOT in any gear!!
Old 11-16-2021, 06:13 AM
Re: Lsvx-t
I can't wait to see a video of it engulfed in tire smoke!
Old 11-20-2021, 01:59 PM
Re: Lsvx-t
Got the intake swap done. New rails too. Intake pipe fits ok but I may have to make changes. Trying to work on my rear bulkhead tomorrow.
Old 12-05-2021, 05:17 PM
Re: Lsvx-t
Been a little while since my last update. I have completed my rear bulkhead with thermal barrier. I have also almost got my 92 conversion done done too thanks to Melis and Dave!!! Some more interior work coming soon.
Old 12-26-2021, 08:59 AM
Re: Lsvx-t
So I ended up picking up a great deal on a used race car trailer. So my winter storage solution is here!!! I need to work on installing a shore power system so I can work on it in here too. It's now a registered 1992 so I made a couple conservative 3rd gear pulls before tucking it away for the season. Oh man this is going to be a very fun spring and summer.
Old 12-26-2021, 11:07 AM
Re: Lsvx-t
Wild project! Congratulations on getting it together and running.
Old 12-26-2021, 04:12 PM
oab_au oab_au is offline
Re: Lsvx-t
Come on Tom, you know the drill,
pictures or it didn't happen.
One Arm Bloke.
Tell it like it is!
Old 01-15-2022, 06:44 PM
Re: Lsvx-t
So since it's slumbering, I found a couple leaks. Rear main housing was aftermarket, and I now seriously regret using it. I pulled the engine back out again because I can't pull the trans without dropping the engine due to bulkhead space. While it is out I removed the subframe and steering rack. I depowered the rack, which was a used unit and also leaking. I installed a new oem rear main seal housing and will be reinstalling the engine and subframe tomorrow hopefully.
While the engine was out I decided to heat wrap my hot side to try and keep engine compartment temps down. Also picked up a turbo blanket as well.
Once the engine etc is back together I will be working on fitting a Nissan versa epas for power steering. I will also be reworking my belts to run with just water pump and alternator. Pics and documentation of epas install to come in the coming weeks
Old 01-23-2022, 03:55 PM
wdb wdb is offline
dances with roads
Re: Lsvx-t
Aww no pics this time. Sorry to hear about the leaks, hope your solutions work well!
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 01-30-2022, 11:58 AM
Re: Lsvx-t
Well engine is back in. Just waiting on a bracket for the idlers to go on where the power steering pump was. Everything is heat wrapped and I added a flex to the downpipe for reasons.
fazer download video instagram
Moving on to the EPAS currently and man have I got some serious work cut out for me. More on that in a future update
Old 01-31-2022, 03:38 PM
wdb wdb is offline
dances with roads
Re: Lsvx-t
Some close tolerances in there for sure! Thanks for the update.
Old 02-06-2022, 10:57 AM
Re: Lsvx-t
Don't mind the mess!! Doing a little electrical house cleaning in between phases of make the new steering column. Was necessary to make a new dash bar due to needing a higher column mounting position. Finally got to use my pipe bender!! Waiting for a few pieces to arrive and I need to source some oddball pieces of steel to make the column so I can sort out the mounts. Just a quick pic to show what's going on
Old 02-06-2022, 12:13 PM
Re: Lsvx-t
It's coming along. It will be wonderful to see it completed. A video of a cloud of tire smoke comes to mind. Oh no, that would be irresponsible.
Old 03-03-2022, 11:33 AM
wdb wdb is offline
dances with roads
Re: Lsvx-t
It would be if there's no steering!
