#3256
Thank you. I have so much to do and I'm tired, but I'm glad that my cars are in good condition at least.
#3257
Back in the garage tonight, working on the Group N motor mount install. Taking a break to run and get some drill bits and grinding bits to make my 1/4 inch spacer.
1991 SVX L JDM 1992 SVX LS-L USDM |
#3258
I started painting today. I think it's important for amateurs to paint carefully and take their time.
#3259
I completed the Group N engine mount install tonight. I've been cleaning under the hood and under the car as I'm approaching each repair. It's looking great so far.
Tomorrow, I'll continue working and move on to the rear differential mounts.
#3260
The shape of engine mount seem to be a okey. By the way, isn't the cross member a little oily? Is there any oil leaking from the rear main seal?
#3261
Once I drive the car more, I will determine what still needs attention. Tomorrow, I hope to replace the differential mounts, PCV valve and hoses, and a few other details.
#3262
Looks good to me. I can't believe it's so clean. Mind you. Mine has 30+ years of 'Rust Check" built up on it.
#3263
The mechanic would have removed either the transmission or the engine when he replaced the seals. It would have been much easier to clean the subframe at that time, and that would be the best timing to do so. There is a long, narrow cover at the bottom between the engine and transmission. It is narrow, but you can remove the cover without removing the engine and transmission. If the seal was leaking, the inside of the cover would probably be oily as well. You can remove it and clean it. I think it is held on by four M6 bolts. From what I recall, the cover comes in two parts and you have to remove one first to access the other bolt. |
#3264
#3265
As you know, natural rubber expands and deteriorates rapidly when exposed to volatile oils such as gasoline and diesel. Engine oil does not deteriorate as much, but it can harden the rubber and cause cracks. With the exception of special rubbers such as oil seals, it is not desirable for oil to adhere to rubber parts. The engine mounts on my SVX have over 130,000km on them and are still fine. I think the leaking oil is damaging the engine mounts. |
#3266
